Installing LS1 Coilpacks on rb25
Im looking to install LS1 coilpacks on my rb25
Currently running with a rb20 ecu w/ nistune anyone know the wire diagram or how to install these, Also if these are compadable with the rb20 ecu w/ nistune if not know what i have to do? Also whats a goog plug and gap to use for the ls1 coils im running 370whp so dont know if that madders |
Google is your best friend man...
bcpr6es-11 w/ a .8 gap is what I'm running for spark plugs. There are many reviews on which plugs to run on the rb25's. I decided to try these out first. There are bcpr5, 6, and 7 plugs referring to heat range. 5 is for just daily driving. 6 is for daily/aggressive driving with some track use. 7 is for straight track use as you will foul out the plugs very quickly daily driving with them. As for the coilpacks: 4 wires trigger the coilpacks. 1 is 12v white. 1 is gnd. black. 1 is ignition signal to the coil packs. I don't remember the exact color... 1 is coil pack ground. You will need to make an additional ground harness for the ls1 coil packs. I took a Black primary wire and ran it the length oh the rb25 coil pack harness then spliced each ls1 coil pack pigtail ground into that then grounded it to the engine. I used this as a reference for each ls1 coil pack when I was wiring in the pigtails: http://www.msextra.com/doc/ms3/pix/ls1coil.gif Make sure you label each rb25 coil pack connector wire set before you cut tap off the connectors. The cylinder 1 & 2 coilpack connectors are the same length when you unwrap the harness so when I did my swap I had to go back and double check the wire colors to each cylinder on an old coil pack harness I had. I hope this helps.
I Cut Vinyl Stickers ![]() www.facebook.com/precisionvinylworks |
google is ur best friend bro http://www.240sxforums.com/forums/rb...pack-swap.html
![]() Join Date: Jan 2010
^^what he said, ask matt on the forums to give you an adapted map. the thread on 240sx forums is the most in depth
