Sunday Sellathon Tein, nismo, z32 wheels
*********Bottom pictures are visible if you right click and click open image url **********
Contact info: Justin 760-420-6347, text or email [email protected]. I have parts I will be slowly adding to this post so check back often Tein EDFC for coils 100 obo....will discount if you buy this with the coilovers, bought this impulsively because it sounded like it would be awesome to have in a car. I changed my coils to something more road race friendly so this needs to go as well. I have a full wiring harness as well as all the motors etc. ![]() https://lh5.googleusercontent.com/-Y...426_144619.jpg Nismo Slave cylinder 100 firm In the pic the slave was just taken off, I put a plug in the hole to keep dirt and shtuff out. The slave worked perfect but I went back to a stock style clutch until I perform my motor swap. ![]() Subframe collars 20 firm These collars I am like 99 percent sure are godspeed. They do the same job as any other collars on the market and this is a cheap upgrade. They do have gouges in them from whoever installed them in my s13 subframe. This is a cheap upgrade and not too time consuming. I have all 8 pieces. ![]() Circuit sport tension braces 60 obo I have no idea how long these were on my car before I removed them, the heim in still in good shape and will likely last a good while. I have all hardware to include as well. ![]() Random beefy tension braces 40 obo These things are pretty beefy, had these on my car for a short period as well and they worked smoothly and held up just like any other tension with good heims. These have FK heims in them so the heims themselves are as expensive as what I am selling the rods for. ![]() Busted up pignose lip. 40 obo. This thing is reccomended for pretty beat front ends, unless your can plastic weld. Its got cracks and is starting to seperate where it mounts. With zip ties and ingenuity you can make it work and stay up but I want a front splitter so its not going on my car. Finned s13 diff cover 25 obo (self explanatory) ![]() Two Digital climate controls with harnesses. One pretty much complete the other missing a couple sensors. 100 for complete and 80 for the one that needs a couple sensors. MOMO Start seat Trying to get out what I have into it 80 bucks firm. Few blemishes but for a drift missile it would be perfect. Eastwood 135 welder Mig welder puts down a decent bead, I always ran it with mig mix gas. Out of wire and I am upgrading to a machine that takes a bigger roll. I can give the next owner flux core wire to test it if they want. Previous owner burned a hole in the outter liner for the gun. I reccomend it be replaced due to this but can be used as is. Regulator has maybe a couple hours on it and was replaced by previous owner right before I took ownership. Perfect for light fabwork like powerbraces, etc. Asking 125 pretty firm. That is what I have for now, there will be more added asap.... Last edited by hellraiser; 05-22-2016 at 02:41 PM.. Reason: Parts sold |
