Old 03-13-2011, 10:56 PM   #1
NismoTuner21
NismoTuner21's Avatar
NismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enough
Formula D Firewall Modification.
I am in the process of my 1JZ swap on my Z32, and the motor I purchased is a rear sump motor. If I go with the rear sump route, I'm going to have to set the motor back about 4.5-5 inches to clear the steering rack, meaning I have to modify the firewall. Z32's are front heavy to begin with, so I thought it would be cool to even out the weight ratio a bit. I will be able to keep my wipers and all of that as well. I will have to re-do my brake lines, which I already planned on redoing since I am deleting ABS. If I go front sump, I have to modify the crossmember, the car will be more front heavy, and there will be less room for the cooling setup. In doing the front sump setup, I will not have to modify the firewall.
So my main question is, are firewall modifications completely illegal? How do the BMI car and D-Macs Solstice pass tech, along with other cars I'm sure? And don't all of the guys running LSx motors in S-chassis have to modify the tranny tunnel/firewall?
I've heard firewall modification is illegal, so I'm looking for a solid answer on this. Thanks in advance!!
NismoTuner21 is offline   Reply With Quote
Old 03-13-2011, 11:11 PM   #2
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
You can put a LSx into a 240 with out modifying the firewall/tranny tunnel. It depends on the install kit, or who makes the mounts.
Some might require you to hit some spots with a hammer.
KA-T_240 is offline   Reply With Quote
Old 03-14-2011, 01:33 AM   #3
90hatchie
Banned from the Marketplace
or ur can buy a front sump oil pan setup and not have to spend HOURS making a new firewall
Old 03-14-2011, 06:36 AM   #4
PoorMans180SX
PoorMans180SX's Avatar
Sell 1JZ, buy VH45.
Both problems solved.
Old 03-14-2011, 06:53 AM   #5
ericcastro
ericcastro's Avatar
also, a Z32 is not gonna be Formula D competitive, so it doesnt matter.
Do what you want.
Old 03-14-2011, 07:08 AM   #6
anton1o
anton1o's Avatar
anton1o is an unknown quantity at this point
Send a message via MSN to anton1o
Best of luck with the Z32, they've never really been the most competitive vehicle in any of the country's people have tried to compete with them!
Not to sure on your question, maybe call somebody from FormulaD?
anton1o is offline   Reply With Quote
Old 03-14-2011, 07:24 AM   #7
PoorMans180SX
I think it's a bit unfair to say that the Z32 is an uncompetitive car, since there have been successful big cars in FD like Soarers, Supras, etc. It's really about the driver and the car setup.
Old 03-14-2011, 07:40 AM   #8
alexanderig
Do what you want.
See i don't remember him asking opinions on his choice of chasis
Old 03-14-2011, 08:28 AM   #9
Csomme
Csomme is an unknown quantity at this point
You cannot modify the firewall other than the tiny bit you can modify for the tranny tunnel.
Dmac's car still has an unmodified firewall. Always had, always will.
Csomme is offline   Reply With Quote
Old 03-14-2011, 10:14 AM   #10
BURSTspeed
BURSTspeed's Avatar
BURSTspeed is an unknown quantity at this point
I have a z32 that I drift on a basically stock setup. Its fine, but the stock steering angle doesn't let you hold that much of an angle during a drift. Thats one thing that ticks me off lol. I definitely say go for the z32 since no1 else is doing it. Sorry this was not related to your question lol.
BURSTspeed is offline   Reply With Quote
Old 03-14-2011, 12:57 PM   #11
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
To the OP, Im in your build thread and when I saw that you wanted to cut the firewall ,I thought to myself dont do it. As for Formula D the mods you need to do will not pass!!!
I say front sump it just to get it done. But if your gonna cut it up then shoot for 50/50 or bust
To the other replies ,being competitive & wining are two different things, money and development can get you either .
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 03-14-2011, 04:25 PM   #12
NismoTuner21
What makes you guys a Z32 can't be competitive? They're an already upgraded S-chassis. I get just as much angle as an s-chassis with knuckle mods, and 2+0 Z's have the wheelbase. I have absolutely no problem drifting my car.
Cool, thanks for responding to my actual question, lol.
Old 03-14-2011, 04:33 PM   #13
RPSil13
RPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-known
sell the rear sump to someone putting a jz into their supra/soarer and get a front sump,
supra/soarer people basicaly throw front sumps away, check supramania.com
RPSil13 is offline   Reply With Quote
Old 03-14-2011, 05:02 PM   #14
NismoTuner21
Well, I got the 2011 rulebook, guess I'll have to scrap this idea.
8.4 MODIFICATIONS OF THE STOCK, OEM FIREWALL AND TRANSMISSION TUNNEL ARE ALLOWED AS FOLLOWS:
Dimension A= Tunnel Width May be no wider than 18 inches
Dimension B= Minimum dimension of 10 inches between the bottom of the
windshield and the top of the transmission tunnel.
Dimension C: Modifications to drive shaft tunnels behind the engine firewall
vertical plane should not exceed an overall width of 10.000 inches.
Dimension D: Modifications to drive shaft tunnels behind the engine firewall
Taper Length from the firewall to the end of the transmission tunnel into the
beginning of the drive shaft hump may be no longer than 36 inches.
No part of the engine casing may cross the vertical threshold of the original
firewall into the transmission tunnel.
No other modifications may be made to the vehicle chassis, frame, or
unibody.
Any holes in the firewall must be of the minimum size for the passage of
controls and wires, and must be completely sealed to prevent the passage of
fluids or flames from the engine compartment to the cockpit.
Old 03-14-2011, 09:30 PM   #15
ericcastro
ericcastro's Avatar
But they dont have the hinderance of steering angle issues and weight/balance that he's about to run into.
And I remember this being a forum.
"a public meeting or assembly for open discussion "
So you can gladly fuck off
or get used to it
Old 03-15-2011, 05:08 AM   #16
GT Motion
GT Motion is an unknown quantity at this point
Who cares what car it is, just go out and try. If you kill it, then you will be known as the guy who killed it in a z32, if you suck, then you can blame the car.
GT Motion is offline   Reply With Quote
Old 03-15-2011, 05:31 AM   #17
ericcastro
ericcastro's Avatar
Anyone who builds a car to Formula D spec, and spend the money for it,(cage, fire system, seats, tech inspection), you want to make sure its gonna work ahead of time.
Thats who cares.
Old 03-15-2011, 06:50 AM   #18
alexanderig
Thats who cares.
not your money or your car so why get so upset over someone doing something different?
Old 03-15-2011, 11:16 AM   #19
TTnickdizzle
TTnickdizzle's Avatar
TTnickdizzle is an unknown quantity at this point
Thats really shitty, i bet it would have been nice to get some out the weight away from the front. But a bright side now the DP should be a lot easier to figure out now.
TTnickdizzle is offline   Reply With Quote
Old 03-15-2011, 12:35 PM   #20
NismoTuner21
Thats who cares.
It works.
I've done 90mph entries, technical tracks/layouts, get lots of angle, and the car has never had trouble keeping up or doing anything other cars could do, and this has all been on stock LSD. I never said I'm building a full professional FD car... I'm just checking on shit like this that would be permanent in case this chassis and I ever do make it to that level.
Old 03-16-2011, 04:46 PM   #21
GT Motion
It works.
Does your car have all wheel steering?
Old 03-16-2011, 05:59 PM   #22
Future_gohan
Future_gohan is an unknown quantity at this point
Do what you want.
That's a such a dumb answer and is completely off topic.
I wouldn't cut the firewall, that's why i sold my ls1 so I didn't have to cut my firewall, I do agree with you on the weight balance issue, but the 1jz isn't that heavy of a motor, so moving it forward a tad won't hurt you that bad, I mean they don't cut the firewall for the rb's and they are about the same size.
Future_gohan is offline   Reply With Quote
Old 03-16-2011, 06:23 PM   #23
ericcastro
ericcastro's Avatar
who's upset??
It works.
I bet if you ever think of making that move, you will rebuild an entire new shell, and just transfer everything over that you need, and get rid of the rest.
Its a lot easier then trying to keep slimming a car down to race spec.
Plus, you can FULLY stitch weld it, paint the frame, tube the front of the frame out, put the cage in, loose ALOT of unnesesary wiring and any other little issues that always bothered you
I wouldn't think so.
Especially with other people voicing the same opinion.
Or should I say warning.
I would hate for this guy to make an awesome car, spend a lot of time and money, and realize to late that its just not a good platform to be competitive in FD drifting.
Now ASB, ECB and all that, please do, it would be awesome.
BTW, you trying to argue with me is off topic.
Considering i have been drifting longer then you have been driving, i may know a couple things you dont
Old 03-16-2011, 07:12 PM   #24
Future_gohan
Considering i have been drifting longer then you have been driving, i may know a couple things you dont [/QUOTE]
That's such a cool thing to know, thanks for letting me know.
Your comments were stupid because they're offtopic and were not needed. The z chassis is an amazing chassis in its self, and you shouldn't be talking down about it. I've driven and drifted plenty of 240's, and 300zx's. and I for one perfer a 300zx any day, but I don't have an opinion on that because you know, you've been doing it longer.
Old 03-16-2011, 07:47 PM   #25
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
He never said it was a bad chassis, he just said it doesn't do well as a drifting platform. I mean an international bus is a good chassis for what its meant for, but it doesn't make a good drift chassis. I for one have been walked by several z32's on a road course, because they make decent platforms for that. The original opinion was given to try to save the OP some money, since in the original post it seems that he is building a FD spec car. Usually there is a reason that no one has had success with a chassis that has been around for years. It's a bit different when its something new that no one has had the time to perfect yet. But you're talking about a car that is at least 16 years old. I think by now if someone was going to compete on a major level with this chassis, it would have happened already.
I had a cool signature
holemilk00 is offline   Reply With Quote
Old 03-16-2011, 07:52 PM   #26
ericcastro
ericcastro's Avatar
^ thanks for summing it up.
Sometimes people need to hear it from others to actually intake the info
Old 03-16-2011, 09:32 PM   #27
ae80siq
ae80siq is an unknown quantity at this point
yaay for 1jz
ae80siq is offline   Reply With Quote
Old 03-17-2011, 11:09 AM   #28
delado
delado's Avatar
delado is an unknown quantity at this point
What makes the FD Challenger any better than a z32?
delado is offline   Reply With Quote
Old 03-17-2011, 11:45 AM   #29
holemilk00
holemilk00's Avatar
Trader Rating: (33)
So you're saying a challenger and a z32 are the same chassis with different body work?
I'm going to start with wheel base, then move on to a turbo inline six vs a v8 with torque, not to mention weight, and a host of other things. They are different cars man. That's what makes them different. That's like saying what makes a 240 different from a ZO6.
Old 03-17-2011, 12:32 PM   #30
Wake
Wake's Avatar
what makes a 240 with a lsx different than a zo6?
Same shit bro thats why people drift corvettes.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
