ASK AND YOU SHALL RECEIVE!!! We've had demand for a legit BOLT-ON RB25DET Upgrade Turbo, and here it is! This is a Genuine OE RB turbo with heavy modifications. Features: -Oil feed, oil drain, and coolant ports accept stock RB fittings. -Adjustable wastegate linkage -Journal Bearing with steel 360 thrust for durability -Billet compressor wheel -Stage 3 turbine wheel Note: Many RB oil feed lines have a built in restrictor which must be replaced with a standard -4 oil feed line. We recommend 450WHP MAX $795!!! + $200 Core Charge (refunded when we receive your old turbo) ![]()
PURE TURBOS 760.721.7669 |
$200 core deposit or send your core in first to waive the core deposit
Them snails are stock RB which are just big enough for 450WHP. You can has custom compressor and wheel size options for specific power / spooling needs. This version is 54mm Billet compressor wheel and 57mm turbine.
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
This is awesome! I'm going to get one for sure! I'm headed to get dyno tuned in the next month or two. I'll get ahold of you closer to the dyno day. Are they all ready to ship?
Yes sir. Let us know when you're ready.
![]() Join Date: Nov 2004
Trader Rating: (53)
I basically know nothing about these turbos so maybe I might have a couple questions a noob would ask that might be helpful... a noob like me that is haha.
Will it fit on a SR? Is this turbo from a RB25? How does it compare to the stock turbo which I believe have ceramic blades or something like that? |
#10 | |
We have done plenty of RB26DETT upgrades including Billet ball bearing. What we have advertised is "the tip of the iceberg". Feel free to contact us for details on a specific custom turbo build.
Sure that's easy. We just remove the wastegate actuator and weld the wastegate valve closed.
#15 | |
Everything from upgraded SR journal bearing turbos to new ball bearing turbos. Just depends on your WHP goal and your budget. PM for details.
Thanks!
![]() Join Date: Dec 2007
![]() ![]() Feedback Score: 1 reviews
On your website you have z31 55hp turbo upgrade, what are the specs and can the same be done for the rb25 turbo since they are similar and how much more does it cost?
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
#17 |
PM'd Thanks!
I'm very interested in this. So this turbo is rated at 450WHP max (Way beyond my needs).
- Do you know how much psi this turbo can handle? - How much psi does the adjustable wastegate allow for? - Can i be refunded my $200 core exchange after i receive and install this turbo? Just to be 100% informed, i can purchase the already modified turbo for $795? I don't have to send mine in first to be modified? I'm very interested, Thank You |
#19 |
![]() Join Date: Jul 2003
Trying to bring this one back...
As I have a Neo motor, are you able to perform this billet upgrade mated to the OP6 rear housings? Thanks...
Ramese Silvia S14-RB25Neo |
#20 |
Sorry for the super-late response. Yes we can do this with the OP6 housing.
#21 | |
Awesome, good to hear... so, do you have stock of OP6 housings, or would I need to send mine in... and also, echoing 2.5T_/<ouki's post...
#22 |
No stock of the OP6 housing right now. You would have to send yours in.
- Max PSI depends on the motor specs. 450WHP is the max recommended output. For example a stock motor will make 450WHP at a different boost pressure than a motor with performance cams. Max boost will be in the 20-25 range. - The adjustable wastegate will get you around 15psi. Use a boost controller to increase from there. - Yes the $200 is just a deposit until we receive your old turbo. - Correct, you don't have to send yours in first. Thanks guys
#23 |
![]() Join Date: Jan 2012
![]() Feedback Score: 15 reviews
Any comparison as to how these perform over stock? Air flow charts? I have the crappy Series 1 turbo in my RB25. I not looking to upgrade the manifold so this looks like it will work perfect for my 350whp goal..
Edit: NVM I saw the other thread you had posted about a customer posting their results. I have FMIC, Blitz intake, 3' downpipe and exhaust, Splitfire coilpacks and will get tuned on a Apexi Neo. I should be ordering later in the month and can post up vids of the dyno pulls and charts.
#24 | |
