please answer!!
i need to know where i have to plug the f8 and f10 plug ? in the s13 sr20det swap into a s14 its the only thing that i need to do before the car start... i need to know where those connector go ?
#6 | |
![]() Join Date: Jun 2008
![]() ![]() ![]() Feedback Score: 11 reviews
I hacked both of those plugs off and hardwired them. Look in Omikron build thread. Edit: You beat me to it. |
I'm in class right now so I can't tell you which is which. Think of it this way, those are power plugs so you will need to supply them (F8 and F10) with power from the F3 plug.
You're powering IACV, Ignition, coilpack as well as Oxygen sensors (these are on F8 and F10) from F3. sr20.hybrids.jp - Installations - S13 SR20DET Installation Into S14 Read the above carefully and make sure you know which wires you are dealing with. However, don't do what the guy did and build an intermediary harness, just hard-wire those plugs (F8 and F10) to F3. Also, don't cut off the wiper motor, amps and such off the F3 connector since these are at the correct length already. I promise you if you read the above you'd know what to do. All the information that you are looking for are in there except for AC, but that's the easy part. |
ok i just did it . i finaly understand but the car wont start and the ECU relay keep clikin when i put the key on ON position.... what i did wrong? ... i think tomorow i will restart from 0 the harness and recheck everything.. :S
EDIT: oh and when i remove the black/yellow wire (fuel pump signal) the clikin stop |
