Old 04-22-2009, 09:15 PM   #1
JeRzY
JeRzY's Avatar
JeRzY is an unknown quantity at this point
sr20 keeps shutting off on me
i start my car and it sits and idles
once i take off it and put in the clutch the car stalls out on me and shuts off
got ne input let me know
thanks guys
JeRzY is offline   Reply With Quote
Old 04-24-2009, 12:50 AM   #2
dOMEmE
dOMEmE's Avatar
dOMEmE is an unknown quantity at this point
never heard this one before
dOMEmE is offline   Reply With Quote
Old 05-01-2009, 12:43 AM   #3
racerocket
racerocket's Avatar
racerocket is an unknown quantity at this point
i motion domeme ... gl
the beast is runing
racerocket is offline   Reply With Quote
Old 05-01-2009, 12:54 AM   #4
artdrifter
artdrifter is an unknown quantity at this point
could you elaborate a little more . like any sounds or anything. smells?
artdrifter is offline   Reply With Quote
Old 05-01-2009, 05:54 AM   #5
Sileighty_85
Sileighty_85's Avatar
Let Down the E-Brake..... lolz J/K
Check for Vac/Boost Leaks
is there any smoke comming from the exhaust?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-04-2009, 11:24 PM   #6
JeRzY
JeRzY's Avatar
well i replaced the battery, re did vacuum lines, some of the fuel lines, rewired fuel pump to a switch so i have power to it
ima invest in a wideband here shortly since my full exhaust isnt hooked up fully just quite yet. lol
Old 05-05-2009, 12:22 AM   #7
Zaku II
Zaku II's Avatar
Zaku II will become famous soon enoughZaku II will become famous soon enoughZaku II will become famous soon enough
sounds like your ecu is fried. try using someone else's or getting another ecu.
Zaku II is offline   Reply With Quote
Old 05-05-2009, 12:28 AM   #8
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
double check EVERYTHING you just messed with.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 05-05-2009, 11:16 AM   #9
305_hustler
305_hustler is an unknown quantity at this point
Y is your fuel pump not comin on???? the fact that you had to run a switch to it means ether your ecu,wiring, or fuel pump relay is bad.
305_hustler is offline   Reply With Quote
Old 05-05-2009, 11:31 AM   #10
JeRzY
JeRzY's Avatar
the wiring was bad
now it runs
Old 05-19-2009, 03:04 PM   #11
iammikeol
iammikeol is an unknown quantity at this point
harness modding sucks..
my car had the same problem. glad u fixed its a bitch.
then the
MAF. started going out.
would not immediately shut off, if it sounds deeper then normal, and rpms fluctuate strangely thats whats going out..
iammikeol is offline   Reply With Quote
Old 05-19-2009, 07:57 PM   #12
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
glad to hear you assesed the wireing
s142jzkillav10 is offline   Reply With Quote
