I swapped my clutch set up and put in ARP flywheel bolts according to instructions below the recommended fsm torque spec. I torqued to 70 ft-lbs with threadlocker on the thread and lube on the head, is this correct? I'm kinda spooked because it's a fairly aggressive 6 puck with a relatively strong pressure plate. all good?
![]() Join Date: Jun 2003
Trader Rating: (129)
#8 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
I have a Spec stage2+ and it's been great for 7 years at $400.
