#1 | |
![]() Join Date: Apr 2003
Tranny sensors/plugs
![]() ![]() wtf are these? me and a friend recently pulled the motor and put it back in. I dont think these were ever plugged in but they recently fell from however they were kept out of sight. What are they? Should they be plugged in?
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
![]() Join Date: Aug 2002
yes you should plug them up. Could be speed sensor, or crank postion /misfire sensor on top of the tranny. More then likely you will need these to drive so best take the time to plug them back up.
kick rocks. |
![]() Join Date: Oct 2004
they plug into your tranny..execpt the one on the very far right side it looks like your engine sub harness connection that connects to your fuse box. only remember vaguely...
I'm here to inform not to conform... ![]() |
Man w/ CTSV & a Car Seat
SR swap...then NO those are plugs you dont need. You got a couple of extra plugs that you dont need in the SR. Go under the car and double check it tho. Im guessing its a S13 SR cuz of the number of extra plugs you got hanging. Out of the whole tranny harness, 3 of those plugs should be connected: Speed sensor, reverse and neutral switch. As for the plug closest to the engine, thats an extra plug that doesnt connect to the SR harness or the fuse box.
well i can say that the car drives fine w/o them. so i think they're just extra plugs that were from the old KA harness, maybe one of them could be plugged in but it's one that dosent really matter much...so i just ziptied them up and out of the way
