#61 |
![]() Join Date: Mar 2011
Pic of the bashbar and got everything all painted as well.
Check out my build! #/f/builds-builds-on...s13-build.html |
#62 |
99% of the way finished. Just welding up, the 02, wideband, oil and coolant temp sensors and oil pressure sensor. I'll upload pics of the interior tomorrow WHEN I DRIVE IT!!!!
Probably nearing the end of the year I'll get this all cleaned up, get a body kit and a fresh coat of paint throughout the chassis inside and out but for now, just making sure everything lines up, and is working 100%
Check out my build! #/f/builds-builds-on...s13-build.html Last edited by blades13.5; 01-21-2016 at 07:50 PM.. |
#63 |
So yesterday was spent recirculating the BOV to the intake, doing all the oil line modifications to now run turbo, Putting together all the vaccine sources etc. The oil feed line would not fit the turbo since the turbo is off an airplane so after some time I found where to be getting the adapter. I'll be picking it up tomorrow it's only a few dollars, and is one of the last things needed before this thing gets tuned!!! Booyah!! Ohhh btw it was raining hella hard so the camera could of possibly taken better pictures but we were under a tarp/tent the all night.
The intercooler makes a really hand table for setting down your tools!
#64 |
So I got the car back from the Fab guy this evening. I found the fitting but need to rig weld it shut and drill a hole 6/100ths of an ince through the weld for a restricter to the turbo.
With nothing else standing in the ways got to cutting the hood, readjusting the seats, and just finishing up a some details before undergoing tuning. Here's the pics of cutting the hood And got it riveted it on well, making sure the cut cleared with the back of the intercooler. Then got it towed to where it'll be tuned. (Couldn't drive it without the oil feed line adapter not being tigged for restriction and I didn't wanna rebuild a journal bearing turbo. (Had to take bumper off) Once it arrived he spent hours doublechecking everything on the motor, looking at my mistakes or things I may have overlooked, then he depined my Fuse box for easier access. Ran the intake pipe further forward to avoid dust, dirt, rain etc from the tire at full lock soaking and clogging the air filter. (Still using the BOV recirculating valve) it's just further down. Tuning Starts tomorrow! (Nistune ECU and I'm still using the Zietronix I picked up years ago with the SR.) after that, wiring will be key!
#65 |
Pics from Caged in Caged Out. Excellent job! Can't express that enough! Here's there logo. Hit them up if your in California!
Thanks again David!!
#66 |
Beginning of fixing the wiring clusterfudgsicle. Looked like the consolt cables were crimped for some reason. :/ So new ones need to be soldiered in before we can start tuning the Nistune ECU. Nistune was also really cool as we lost the code for the software and last second, they came through for us and helped us access the software. +1 for Nistune.
Also thanks to David Maye for welding the oil feed line shut as a makeshift oil restricter. Part was near impossible to find locally. A new restricter is gonna be purchased but this will do the job for tuning. Yayaya!!! Put some fluids in as well and slapped this awesome sticker on the swirl pot! She may not be the prettiest right now, but she's almost there. No garage queen either.
#67 |
![]() Join Date: Jul 2009
![]() ![]() Feedback Score: 13 reviews
I can appreciate the vision and the drive you have to realize your dream. Going v-mount is something I always wanted to do and yours looks pretty solid. It seems like you have good tech and fab support. Don't forget to add ducting to your cooling so it can actually work. I hope the exterior catches up too. I reached a similar stage where my chassis is fairly sound but interest and funding has been cut so my exterior reduces expectations. Good luck and keep it moving.
Here's some good visuals on ducting from Mannykiller #/f/showpost.php?p=5...&postcount=316 |
#68 |
Alright so prepping for the cars first time on the track we went over every nut and bolt on the car, filling the fluids, resoiliering some wiring, and some other minor things. The oil feed line we welded shut was destroyed when we tried drilling a hole through it, the drill bit broke, so I ended up ordering a new one. The parts store was closed that day but the owner (racing enthusiast himself, showed up at the shop, just so I could pick it up. Eventually we have up(temporarily) on tuning the Nistune ecu because no matter what we did, the ecu didn't seem to respond to the computer. Even restoring the computer and reinstalling (along with redoing all of the maps and checking the voltage wires on the chassis harness to make sure it was receiving signal didn't seem to help, so literally the night before the event, Jake picked up an SAFC to borrow to get the car up and running so we could Hoon. I also picked up a white bunny clutch setup to support the additional stress put on by doubling the cars power. Even at this moment it hasn't been installed but it's in the plans. Seats were installed. Harnesses were borrowed and we found a bunch of tires outside tire shops and were even given sets of decent tread tires by a few shops once I described what we were up to. Truck and trailer bailed out on us last minute so we found a truck and trailer literally the morning before leaving. (Grange motor circuit is about 5 hours away from where I'm living currently) so it was definitely a team effort. Anywho... Here's some more pics of that whole adventure!!!
White bunny 240mm Clutch and flywheel setup Tuning was done at the track as we literally had just started the car to make sure the SAFC was readings properly and the car ran. Here's the vid of the first time the motor ever saw boost!!! (First try at starting too) VIDEO:http://s65.photobucket.com/user/Srbu...nzhwe.mp4.html On the way there out car trailer and truck spun out a full 180* on the highway. Fortunately there was no one there. The car didn't flip and we didn't hit anything. Pics at the track: Wanted to say thanks to everyone's support and talent on this build so far!!!! And I bent the hood backwards in the vent so it was a smooth transition which I thinks looks better and it's not flopping around or in the way and less chance of cutting your hand. Not even an hour after the tune was dialed in, the BOV somehow got stuck open when the car spun out sucking up dirt directly into the motor causing a knock... Which sucks major balls because these are forged internals. Of course I didn't really know the damage done until it got torn apart so here's was the breakdown of the motor. Intake Off Turbo manifold off. Timing cover off Head off Pics of cylinders and bottom of the head Spark plugs So now I'm looking at pretty much rebuilding a different KA from scratch. For a short time I'll probably throw a stock KA in the car until a properly built motor is financed. Kinda sucks but every other piece of the puzzle is finally figured out. Another KA can be transplanted back into the turbo setup for the meantime even if it doesn't last forever, it buys me time! Drift Video Memories... (When it was NA last summer) VIDEO:http://s65.photobucket.com/user/Srbu...x7dwq.mp4.html It'll only be a matter of time before its back out sliding again. Pics will be uploaded as I piece the car back together and rebuild a new motor!
Check out my build! #/f/builds-builds-on...s13-build.html Last edited by blades13.5; 02-19-2016 at 03:13 PM.. |
#69 |
Major bad luck, never seen a bov get stuck open before. Lol how did you manage to spin the truck and trailer cruising on the freeway? That sounds like quite a moment.
#70 | |
I'm not saying that this is necessarily the way to fix the BOV situation, but as much as it sucks, if only the BOV was set to recirculating, I'd be driving a car right now... It's only a matter of time though. The car's been through worse and its not like its a MAJOR setback...like if the chassis were twisted or anything. Just gotta find another dual cam and put it all back together.
#72 |
Sr20's lack power, and especially torque, are too fragile and expensive to make the swap worth it, and I'm done with anything regarding SR's. Stupid engines they are. I'm thinking besides the fact that RB's and 1J/2Js probably wouldn't fit with the Vmount setup, RB parts are too hard to find, and need built rather extensively to be reliable, and 1J/2J trannies are too expensive to make the swap worth it.
KA's are capable of holding plenty of power and really impressive amounts of torque with a built bottom end which means less turbo lag. Especially when paired with the Vmount setup. They're cheap, easy to find/source, and besides, I already have the tune, white bunny clutch setup, and exhaust all bolt up now ready to go which means less down time, not to mention, I can use the old motor as a backup and can have pretty much 2 of everything in case any problems arise in the future. KA's are fantastic motors! The only thing I'll ever swap into the car for now on will be a KA or an Ls1 V8 possibly utilizing the Vmount as well if I boost it, but in all reality I don't have really any time or money to begin building one, and I've already been building this car for 7 years. I just wanna get some seat time and become a good driver, and you don't need too much power to do any of that. The previous KA I just had was gonna be boosted at 22Lbs making 376 to the wheels on E85. I'll be doing a similar setup with the next build but with a twinscroll, a twin plate clutch. S2000 coil on plug, Map setup, And custom plenum. And this time I'll be hot tanking, powder coating, and polishing stuff so it'll atleast look like how it performs. It'll come with time though.
#73 |
Engine #4 lol:
Drove down to LA to go pick up a stock KA block. Came off a running S14. Head looked extremely clean and crank spun extremely easy. So easy in fact, you could spin it pretty easily with you hands turning the pulley. Ended up moving yesterday for a new job so I had 3 days to assemble the new KA block and get it running. Here's the engine build. Cleaned up the valvecover. Painted a few engine components. Picked up gaskets and new (colder plugs) This gasket was by far the hardest one to pick up. Luckily, with less than a day left I was able to pick it up. (Even the dealership didn't have them) Got the Whitebunny clutch, intake and exhaust manifold installed. Starting looking really good IMO! Then put it in and installed everything. At present moment this car runs ABSOLUTELY FANTASTICALLY! It's such a joy to drive. The power is just wonderful, even though it's not like holy crap levels of power, it's definitely a great balance for the car and a blast to play with! Dropping it in. Meanwhile, Jake pulled apart the old block and took a look at the old rods and Pistons. Pistons obviously are toast, but the rods are more than likely reusable but he's gonna bring them by the machine shop to have them looked at to know for sure!
#75 |
Well atleast it's running now!!! ![]() ![]() ![]()
#78 |
![]() Join Date: Sep 2008
Trader Rating: (18)
Man..... I'll tell you what..... this car has seen and been through some serious shit. Lol
Its inspirational nonetheless just because he had every reason to scrap the car and start a new build, multiple times. This car is fucking badass still. Just needs to get some funds together and actually FINISH THE GOD DAMN CAR !... |
#79 |
For the love of god clock the turbo
MRP Manufacturing |
#80 |
Picked up a Z32 trans since his transmission is having issues with 2nd gear. And a second set of rebuilt and powdercoated calipers for a rear hydro brake setup and a replacement Drum brake setup with hubs.
Also picked up some Aerocatch patches to properly secure the hood. KAT Plenum came off a 600HP KA. Damn! I can't wait to install this!! Some GKTech Dual Caliper Drop knuckles And some ISR front and rear sway bars and steering column bushing. Stuff just waiting to be installed:
#81 |
1. You make your own luck, by being smart and doing it right the first time.
2. RS Enthalpy has nothing to do with your shit SR saga 3. My car dont run so buy a bunch of shit that has nothing to do with fixing the prob. 4. Wife>DriftLife 5. RIP rhs13 |
#82 | |
Very true. Why all the hate though?! Srs are pretty shitty. RS's inability to reach back to me after being as polite as possible with them, after months is why I don't reccomend them to anybody. My car didn't run so I spent a ton of money having "reputable" shops like TFworks and we'll respected local engine builders rebuild that motor. In the meantime I bought more parts. 4.Agreed. Shit happens though. RPS13* lol. Did you Car die?Interiors gonna be powdercoated by the end of the year on a rotisserie after the last remaining fabwork is completed.I'' really short on time right now though, as my job has got me working a lot.
#83 |
How do you duct air to the IC?
Seems like your design has air coming in the nose then going right out the vent.
MRP Manufacturing |
#84 |
I don't use any specific IC ducting. Hasn't needed it honestly. Driven it through traffic in 100+ temps. Taken long trips without any heat soak or overheating and didn't have any issues at Grange either with either motor.
#85 |
You were running with no bumper though? Not that it won't work, just looks like it is terribly inefficient
MRP Manufacturing |
#86 | |
I just like to reassure any potential Vmounters that so long as you have a large radiator, swirl pot and proper coolant routing, you shouldn't have any issues with overheating, with or without ducting. Too many people tried talking me out of doing it saying it was gonna overheat and cause heatsoak, etc. I was playing around with some mockup ducting for size/figment and placement though. Including an IC shroud.
#87 |
Rear Suspension Revamp:
MB Battles Rear PBM Swaybar end links. GKTech RLCA's, 15mm Axle Spacers, and dual pot stainless hydro brake lines Beginning of Installation: Replaced the Ebrake assembly since the old one went bad: Test Fit: Final assembly: Got some rubber on the wheels.
#88 |
So not a whole lot has happened since the last post. But I did get it back on 4 wheels and got a few new upgrades.
Picked up a custom LHD ATPerformance Oil Catch Can as well as all the AN lines and fittings to replace the Fuel lines, PS lines, and Oil cooler lines and catch can with some weld in bungs to finish the job. Also picked up a braided clutch line to clean up the engine bay. Only other lines that I'm looking forward to replace are the brake lines.
| clean sr20det |
