![]() Join Date: Oct 2008
SR20DET ACT unsprung 6 puck, NEED GONE
$250 shipped, this retails for around $571, and your average sale price at around 5 hundo...
ZERO MILES... as in NONE... maybe 12-14 feet on it, you can literally see where it looks like it was backed out of the garage, parked, and pulled back in... Pressure plate has some wear on the fingers from a seized throwout bearing, but nothing really worth mentioning, no major scoring or anything like that, just took off the surface layer or paint or w/e.. no wear on actual clutch friction surfaces at all... pics, pressure plate is dirty cause i didn't wipe it off after i pulled it from a 0 mile SR... shows wear. ![]() you can still see the factory machined grooves in the pressure plate!! ![]() so meaty! ![]() MINT CONDITION!!!! ACT 6 Puck Unsprung Xtreme Clutch Kit w/ Xtreme Pressure Plate Clutch Kit for 89-98 SR20DET. A heavy duty clutch that can withstand up to 576lb of torque and anything you throw at it. Designed with a 6 pad engagement, this clutch gives increased torque capacity, longer spline life, and reduced drivetrain shock. The spring center improves engangement for daily driving and road racing by providing a smooth transition of torque transfer to your drivetrain. Each ACT race disc are SFI certified allowing these clutches to be used in most legal racing competitions where SFI Specificiations are required. Specs:
