#1591 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
i was about to edit my post.
im just running it for stock RB20 setup for now. 7 PSI stock but good up to 10-12 PSI but i heard this BOV dont hold over 14 psi? |
#1592 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Despite being stronger/harder, do any aftermarket tie rod ends have more threads on the rack side for spacers?
Or are they the same as stock?
http://buildmakecreate.tumblr.com/ |
#1593 |
If that's the case, your fine. You can also swap out for a Bosch BOV (~$30-40 at Advanced Auto). Search google for specs and install, very popular.
#1594 | |
Check out Phase2Motortrend There is a good selection of tie-rods with built in spacing, no need for washers and that crap. I have Pike Peaks, not bad. |
#1595 |
![]() Join Date: Sep 2009
I think I read something about this before, but now I don't remember what the answer was - when I lower my car w/ my coilovers, I get a clunking sound coming from the front, drivers side, when going over bumps. When I raise it a bit, it disappears. Why?
#1596 |
![]() Join Date: May 2004
Trader Rating: (26)
^check the locking collars (unsure if i used the correct term)
Will the harbor freight valve spring compressor work with the valves springs in a KA motor? it looks similar to: reason why i ask is because; in the fsm, it shows a completely different type of valve spring compressor along with an adapter: ![]() the head is already removed from the block, if that makes a difference. |
#1599 |
I just made a exhaust out of 2 3/8 straight through to stock muff. It sounds okay; I haven’t driven the car yet, but will in a few days. It’s not exactly deep sounding. It’s quiet at idle though.
#1600 |
Trader Rating: (24)
power steering/cooler question
ok so i made a p/s cooler. the one with blue fitting goes to the cooler to the can. the other one with with polish fitting is the one i bought from rawbrokerage, the other end of it is suppose to go on where the blue fitting is and the other end is suppose to go to the pump. so the blue fitting is suppose to go to where the polished fitting is. but they got different thread size. either way i still have to buy another fitting. but i want to know if it matters if i just dont switch it |
#1601 |
What do these plug into?
It was a year ago when I pulled this thing apart. The plugs covered in foam and you can't see go to the cigarette lighter, this is under the center console in a S13 btw. |
#1606 |
![]() Join Date: Aug 2009
question
I have a couple of quick questions.
I have some coil overs, but they are seized. What is the best method of unseizing them? Also, while I was changing my water pump gasket, I lost the radiator cap. I know, but shit happens. I bought some caps from auto zone, but after driving a while, the coolant goes into the reservoir and doesn't go back down until the car has cooled down considerably. Biggest headache ever. So, I got the highest level psi auto zone sold, but I think the size of the gasket is incorrect. Basically, how do I get a working cap? BTW, I was told by the previous owner that it is not an OEM radiator. One more question. I need to change my exhaust manifold gasket, but the sensor that goes into the engine is in the way, which to take off is blocked by the heat shield. Should I just cut the wire? and do I need the heat shield in my engine bay or can I go wihtout it? |
#1608 |
![]() Join Date: Oct 2005
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
Stupid question, I know, but will an S15 turbo work with an RB20det? My turbo is blown and I have this S15 turbo on my shelf...
www.realize-jp.net |
#1609 | |
Engine 4,000 miles Trans 60,000 miles Diff 100,000 miles Rad Hoses 5 years Waterpump 100,000 miles Timing belt 50-90,000 (very vehicle dependent) Accessory Belts - Visually/5 years Balljoints 10yrs/100,000 Bushing 10yrs/100,000 |
#1610 | |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() Feedback Score: 20 reviews
If you are going to events, I would change it after every event or two.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
#1611 |
![]() Join Date: Oct 2009
![]() ![]() Feedback Score: 11 reviews
aha that looks super nice
![]() i checked it out and bolt pattern is 5x120, idk how that fits but apparently it does haha. is it a little loose cos i think the holes are significantly bigger than the studs btw i'm pretty sure thatss the parking garage where the new-er kaiser hospital is in ontario lol am i right?
@dangerdamian |
#1615 |
Trader Rating: (44)
That's there for a reason. It's factory Nissan. Everyone has it.
#1618 |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Ok heres one...
Im swapping in an SR in a few months, and the rear main seal on my KA (my daily driver) has started to leak. I think its been leaking for a while, but has just recently started to make the clutch slip on very hot days. For the most part, the clutch is fine, i just have a bit of oil coming out between the block and trans. Until now, Ive always run synthetic oil. Would it be in my benefit to switch to conventional? I would assume conventional wouldnt leak as badly. I lose about a quart between oil changes. And theres no way im pulling the trans to fix it if ive got an SR sitting in my garage just waiting to go in. So conventional or synthetic? Is it worth trying one of those "Rear Main Seal Fix in a Bottle" things? How long you think i've got before I need to borrow another daily, or swap it? aka How long until my clutch starts slipping to much to drive it? |
#1619 |
#1620 | |
![]() Join Date: Mar 2008
| 180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
