s14 wiring question 95 zenki convered harness into a 97 kouki
I own a 97 240sx. Im looking to buy a s14 sr20 converted plug and play swap thats running into a 95 240sx OBD1. only problem is even though it is an s14 chasis and the plugs are the same, from research im seeing that the s14 dash plug (f4) have minor but some differences in the pinout between zenki and kouki. I have pieced together a s14 dash plug chart for the sr20. but what I need is the USDM F4 plug charts for a 95 and also one for a 97 so I can cross reference the differences between the 2. In short its like puttin a ka24de with harness from a 95 into a 97. anybody understand what Im sayin lol
![]() Join Date: Dec 2002
For the SR wiring there isn't anything different enough to matter IIRC. You can download both FSMs and verify, but the major changes happen to be for things you won't use anyway.
well i mean the setup im about to buy, is an s14 sr20 with a converted harness for a 95. I have a 97 usdm fsm. But I cant figure out the dash plug chart (f4 plug). I just have to convert the plug to work with a 97 instead of a 95. anyone have an idea about whats different???
Your just going to have to download both the 95 and 97 FSM, grab a beer, and go from there.
![]() Join Date: Sep 2004
probably 3 or 4 wires that you need to move around. I'm in the same boat, my speedometer isn't reading anything but from what i can see that's not even affected by the f3 plug. That's the stupid plug that goes straight to the transmission.
But It's been a while of course I could be wrong.
Wayne |
