![]() Join Date: Oct 2008
New/Used/OEM *COMPLETE* SR20DET Part-Out! A lot of Quality Parts!
So here is the story behind this motor. I purchased it about 2 years ago. My plan was to put it into my GC8 (you might have seen the build thread). I have changed routes and now am selling the complete swap...in pieces. The motor was recently disassembled and machined by Frank Siharath of RaceTune and/or Garage Boso. The motor was disassembled as a complete motor so there for I have everything for it. You will need new rings if you plan on buying this whole thing as 1. I do not mind shipping under purchasers expense, but of course I rather do a meetup if manageable. The motor only ran in my impreza for about a total of 4min before we pulled it. We only ran it to make sure the wiring had worked. Before the first start-up everything aftermarket was brand new. Here is the following list of things I have:
Contact: PM/Text/Call Rob at 707-342-2214 Thread Replies will be answered ASAP! via PM -All parts are for/came off of S13 SR20DET (Redtop) -When a part is sold the picture will be deleted and the sold item will be stated at the bottom of the ad. *NEW* Mishimoto G-Line Intercooler (Has been sitting in storage and will not come with couplers)-$120 ![]() *NEW* Tomei Shim Kit (You will need this kit if you plan on building a cylinder head)-$80 ![]() *NEW* OEM Fuel Rail-$75 (INJECTORS ARE SOLD) ![]() ![]() *NEW* OEM Water Pump Studs-$10 ![]() *NEW* OEM Thrust Washers-$3 ![]() *NEW* OEM Rear Main Seal-$20 ![]() *NEW* Set of NGK BKR7EIX Plugs-$25 ![]() *Custom* IACV Blocking Plate-$30 ![]() *Custom* Upper Water Neck-$30 (It directs the Water Neck to come out at at 90 degree angle. I was using a MKIV Supra Upper Radiator hose. Worked perfect.) ![]() ![]() OEM IACV-$40 ![]() ![]() OEM Upper Water Neck-$15 ![]() ![]() Please feel free to PM me on any parts you are interested in or contact me by my phone number above. I will be posting more items for sale in the next couple of days. I'm willing to work with anyone on pricing. Parts Sold: OEM Exhaust Manifold ECU #63 Tomei Poncams Z32 MAF DIF Water Neck Adapter OEM Heat Shield Machined Block Crankshaft OEM Starter KA Alternator 370cc Injectors S13 Apexi Power FC Brian Crower Valves Machined/Decked Cylinder Head HKS EVC-S Boost Controller Exedy Hyper-Single OEM Oil Pump HPI Oil/Block Adapter Mishimoto Upper Radiator Hose OEM Head Bolts Neukin Turbo Manifold Garrett GT2871RLE DIF Turbo Lines D-Max Pulley Kit KA24DE Power Steering Lines CAS OEM Valve Cover 550cc Injectors Power Steering Kit OEM 02 Sensor (Skinny)
*PowerPlenty* RWD SR20DET/Impreza GC8 Build:http://imgur.com/a/7KDa1#0 Last edited by angeldunk707; 04-12-2013 at 10:38 PM.. Reason: 02 Sensor sold |
You wouldn't happen to have a front S13 subframe would you?
"I am not good English, I like the drift" CHINA DRIFT "some guys have a better relationship with their car than their wife haha. sad but true." SECRET SOCIETY |
![]() Join Date: Nov 2009
Trader Rating: (35)
![]() Feedback Score: 35 reviews
BUMP!!! great seller, got the water neck in near brand new condition... even threw in a small tube of RTV!!!! future buyers, don't hesitate... this guy is legit and provides detailed info...
