Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 02-03-2013, 09:02 AM   #1
Mintbagel
Mintbagel's Avatar
Mintbagel is an unknown quantity at this point
Z31 na stalls on start up
Ok so yesterday went to go to the store stopped for gas, filled it up, tried to start it after that and kept proceeding to stall immediately after startup, tried giving it gas and it would start choking out. Got it home, checked for vacuum leaks or anything else that obviously looked wrong, couldn't find anything. Put the ecu in diagnostics mode and it didnt give me any codes. Cleaned the maf, tried swapping the fuel filter, and have just now took off the iacv to clean but a hose was rotted out so have to go replace that, but nothing has worked yet. Anyone have any ideas with this... Thank you ahead of time
Mintbagel is offline   Reply With Quote
Old 02-04-2013, 08:51 AM   #2
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
so it wouldn't start up at all after it died?
Check for a dead/dying fuel pump.
z31 Lovin'
http://imageshack.us/a/img337/2396/lowerit.jpg
DeleriousZ is offline   Reply With Quote
Old 02-04-2013, 09:08 AM   #3
Mintbagel
Mintbagel's Avatar
No it will start, but then stall right away, even if I give it gas
