Mechanice whine when clutch pedal depressed
Hey guys and gals, Ive noticed recently that whenever I depress the clutch pedal that I get a really wierd mechanical whining noise.
The only way I can describe it is that it sounds exactly like the A/C compressor when it is compressing. This is my first standard car and I didnt know if this was normal or not, but its pretty loud. Anyone know what it is or what is wearing out on me? Thanks a bunch! |
Actually it only happens when I press the clutch pedal. I searched a bit more and throw-out bearing is comming up a lot, could that be it? Other than that the pedal pressure is nice and stiff and there are no abnormal clunks that I can hear.
![]() Join Date: Jan 2003
if its teh wrong or old throw out bearing itll deff make that noise, its a stock 5spd right, not swapped to 5spd?
***NASA HPDE Instructor*** |
![]() Join Date: Nov 2003
it's the throw out bearing This makes noise when the clutch is depressed. The pilot bearing will make noise with the clutch not depressed. That means while you're in a driving.
I'm driving fast ![]() -drew |
i got the same problem. when i let go of the clutch it whines, but then it goes away after a few mins of driving. i think its the clutch slave, but havent really had a chance to look at it yet.
A throw out bearing will only make noise when the clutch is depressed cause that is the only time it is being used...The pilot bearing will make a noise when the engine is idleing and in gear with the clutch depressed. This is because they are now spinning at a different RPM...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
