would anybody like to give me some tips and tricks, on going about doing my 2jz cd009 swap into my s14 that im eventually going to do, i like to gather everything all together at once, planning on keeping it stock ecu and doing it how "motionautotv" did his giveaway car. keeping this car strictly street only. and would really like help on how i would go about getting the speedo to work
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Alright, get your bib ready.
2jz swap thread, hella info #/f/showthread.php?t...d.php?t=384161 CD009 trans swap thread #/f/showthread.php?t=628596&page=7 jz swap is straightforward, cd009 depending on what adapter you go with is straightforward as well. Step 1: Beat the shit outta your trans tunnel Step 2: Beat the fuck outta your trans tunnel some more Step 3: Finally realize that you need to beat the trans tunnel again. Step 4: Admire how the transmission hangs really low.
![]() Join Date: Jul 2005
I don't understand how I fit a 4l80e under the S14 and its as high as every other trans. 4l80e is 250lbs monster. Why does the cd009 hang so low when the 4l80e must be larger, heavier, does not? |
I drilled out the welds on the transmission brace support and re welded it on further back and used a stock cross member for the transmission. freed up some space and my cd009 sits even with the frame rails on a maverick motorsports adapter.
also hammered out about and inch extra room around the bellhousing of the firewall. |
