![]() Join Date: Oct 2006
SR coil pack covers, hip replacement, fuel cell, etc. ITEMS ADDED!
Location: Greensboro Contact: text or call 336-264-4458 Shipping: YES, everything but the fuel cell First item, 16 gallon RCI fuel cell with 0-90 ohm fuel sending unit. Dual outlet, one can be used for feed the other return. Also has a vent outlet on top. This item is new and has never been used. It has foam inside to decrease slosh also. I think I paid around $200 shipped for this, I'll take $150, again no shipping on this item. Next up I have a Speedway Motors power steering reservoir, this is pretty much what Chase Bays used in their power steering kit. It has an AN-10 outlet on the bottom and a AN-6 fitting on the side. Comes with mounting bracket. This item is new in box. Asking $30 shipped. The next item I'm not even sure I've even seen listed anywhere before. If you've ever known anyone to have hip replacement surgery this is what would have replaced the top of their femur. Of course it's new and never been implanted in someone, DUH. I had plans of making this into some sort of shift know or tow hook trinket but it's ended up just sitting here instead. $50 takes it, do what you like with it. Next, something not a random, I have S14 Kouki and Zenki grilles. These are fiberglass with wire mesh inserts. They do not have mounting holes and you will have to drill them. They have very minor scratches, nothing that a little sanding before paint won't take care of. $25 each. Here I have 2 SR20DET coil pack covers, an S13 and an S14. The S13 is in blah shape, needs to be painted or whatever, $20 for it. The S14 cover is in better shape, take $30 for it. I have this Competition Engineering weld in fuel sump, it has 1/2" npt fittings already welded on it. Also a little minor surface rust, nothing a scotchbrite pad won't knock off in a few minutes. Paid $66 + shipping. Would like to see $50. I also have these L.E.D. boards, every other L.E.D. on the board is orange, the red. There are 12 L.E.D.s per board, so that's 6 orange and 6 red. This would work for anyone wanting to make L.E.D. tails custom and not have to have seperate boards for brake lights, turn signals and park lights. DO NOT BUY THESE THINKING THEY WILL BE PLUG AND PLAY, you're going to have to do some work to make this work. If you do not know how to use a multi-meter then don't even buy these. I have a few pig tails that I'll give to whoever purchases these, the AA battery is just for size reference. You get all pictured here for $50 shipped. I also have this NEW S14 5 speed trans wiring harness. I bought this new from Nissan for $240ish, and never used it after I converted my S14 from auto to manual. Replace that old brittle, oil covered wiring harness on your car with this awesome fresh harness! According to my Nissan dealership there are only 2 left in the U.S.! Price is $200 shipped, so basically you're saving shipping and save $50 on top! Last edited by onehundredoctane; 11-08-2012 at 02:19 PM.. Reason: items added |
Im a certified surgical technician.....just so you know..when we do hip replacements, that piece that you have there....if its titanium...which it probably is...when 100% STERILE is anywhere from 7k to 10k.....im not saying it has that value now...but thats what hospitals pay for one of those implants.
#8 | |
Payment rec'd, shipping Monday! |
