![]() Join Date: Jun 2008
My power band seems to act up.
-At times when i punch it, it'll pull fine. -other times when i Punch it, you won't get the hard pull till almost at the very last second. -Then i have times when i punch it, and it won't pull hard at all. (like you cant feel the boost kick in or something) It can't seem to be a boost leak, cause a boost leak would happen on every pull right? Here are my mods: S13 SR20DET Red Top HKS Hi Power Exhaust Megan TP & DP Trust FMIC Koyo radiator HELP?! thanks for your time.
im having this problem, and finally found the solution! my internal wastegate was stuck.open. i would build boost, hold it, hold vac, but the car never actually pulled. only early morning when it was cold out! even then only sometimes. but i ordered a new turbo and she a beast again.
#3 | |
Well the turbo is going bad, but this is the 2nd turbo on this motor, and i had this problem since i swapped out the turbo. This boost problem is such a tease haha. who knows, maybe i haven't ever driven my car with its full potential. I ALWAYS seemed to have boost problems, sad to say.
yeah man that sucks same with me kinda. one day the car was sooo much faster i was like wtf?!? and so it woukd be fast sometimes and not others. once you replaced your turbo did you tune your car? i know that has whole lot to do with it. or maybe try n external wastegate setup. i think i know if the turbo.spools and holds boost and vac, its your wastegate thats the problem. mine was stuck open. new turbo nd wastegate nd a tune and shes great! good luck man keep us updated
