Fuel pump and no spark after changing starter
So a few weeks ago my s14 sr20 was running fine, then the starter went so I changed the starter and then my fuel pump went and I had no spark. I hard wired my fuel pump and now im getting gas but still no spark. I seen my wires coming from fuse box in engine bay were grounded down from being so low. So I swapped in an other fuse box and still nothing. I also changed the igniter chip and that Dident do anything. Any advice?
You had some wires grounded out? Check fuses and fusible links? I've seen reman starters bnib with the solenoid wired wrong...can you compare with your other starter or did u have to turn that in as a core?
