![]() Join Date: Oct 2011
![]() Feedback Score: 15 reviews
Passenger rear caliper locks
Ok so i have a 95 240 base model that would lock the right rear caliper. I decided on doing a brake conversion so i went r33 brakes, after changing calipers, rotors, ss brake lines, z32 bmc and bleeding, the passenger rear caliper is still locking. What could be the problem? It has new brake fluid, New ss brake lines
Sent from my HTC6500LVW using Tapatalk
MmmmmmTACOS |
You may need a new brake master cylinder.
Do need the Factory Service Manual? Click here. |
Fluid was running perfectly fine when I was pumping the brakes with the line (that goes to the caliper) was off
MmmmmmTACOS |
![]() Join Date: Feb 2012
Trader Rating: (37)
It can't be but a couple of things. Master cylinder, clogged line,...try readjusting the e-brake cables?
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
