| South Western States Arizona, California, Hawaii, and Nevada. |
This Saturday! HUGE Discounts for Dyno - This weekend only!
Hi Guys!
Check out the link! HUGE DISCOUNT FOR DYNO THIS WEEKEND! Shop is located in Mission Viejo, only 20 minutes from LA, 45 from San Diego MAP TO SHOP - PFC L JETRO -380 ONLY! Call me if you have questions 562 -331 - 7039 Check out the rest of the rates as well
Like Me on FaceBook !
Also,
If you guys have a car that doesnt have an EMS yet, but you just need the car tuned on the dyno mechanically I can offer the following for 240 per car - FUll Diagnosis with vacuum leak test - Timing re-set and timing adjustment according to dyno and data logging -2 hours of time on the dyno for me to adjust mechanical inputs such as CAS or dist, spark plugs. - Full Tuning of your aftermarket boost controller - Full data logging using the dyno equipt wideband 02 sensor on hand - Power pulls as well as baseline before and after tuning and adjustments
