Help! My coilovers rubbing rim!
i have 18x8.5 xxr 962s in the front of my 91 s13. my front left rim is rubbing the spring on my new godspeed coilover setup.. i am already using the biggest possible spacer before i run out of thread on the wheel studs.(not sure what size spacer) im not sure what to do next? will a alighment fix anything? it does pull to the right. im kinda new at zilvia. any help would be appreciated.
thanks |
#6 | |
![]() Join Date: Nov 2006
you have 18x8.5 sportmaxes [xxr's] probably with a 35mm offset.
IT WILL RUB. get spacers. or buy rims that actually fit.
![]() Quote:
that makes sense... but it sounds like metal to metal and thats the only place... and i was having fitmint issues when i did the install. im going to get a alignment 2marrow and see if that does anything. it pulls hard to the right.
#16 | |
![]() Join Date: Dec 2006
Trader Rating: (41)
Get a bolt on 15mm or larger spacer. It should clear the coilover. Are you sure you aren't rubbing your fenders? |
#17 |
haha. they are 5 lug wheels if i knew this would be a issue i would of bought different rims way bback then. i rolled the fenders so it doesn hit there. but left tire does hit the inside fender wall in the front when i turn hard right
hey i hade the same problem i have 17x9 sportmaxs on mine and it was rubbing the coilovers to i got a 10mm spacers from (orilly auto parts) and the bolts that hold the coil overs on the hub the top one on my ksports was slotted so i moved it out and it fixed it check that when u get the alingment done :>
#22 | |
![]() Join Date: Nov 2008
![]() come home soon btw ![]()
![]() perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines |
#24 |
![]() Join Date: Jun 2004
Trader Rating: (73)
Look at his reg date, maybe he hasn't signed on since he registered so EVERY thread is new to him.
| 18s, coilovers, rub, spacers, sportmax |
