Engine problems
Hello everyone I have an s14 with the KA24DE with cold starts it will take multiple cranks to start up the car and when it starts it'll idle irregularly until it levels out (levels out low at 800rpm) roughly, has anyone had this problem before I know MAFs are known to go bad on 240s
I had a rich idle issue with my KA-T and when I changed the coolant sensors, it helped significantly. So it's not the coolant in question because if the sensors are not reading the temperature correctly, you could still have issues.
I might start there because they are just a few dollars each.
