![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
530 518 5235 for faster response call/text anytime
RB20 full swap stock RB20 with KA trans with racing clutch comes with uncut harness with ECU (harness wired for S13 sold) lower harness needs to be loomed comes with tranny and motor mounts new oil pump new water pump new thermostat new gasket kit most of it installed except for the head gasket summit racing FMIC and intake pipes already welded and presurized. no leaks. with fmic core new NGK spark plugs changed all the lines new slave cylinder RB down pipe R32 crossmember stock radiator with hoses new valve cover gormets just filled it up with mobile 1 synthetic theres prolly more that i cant think of right now, comes with everything you need! $1500 pick it up add $100 for HKS shroom intake with new filter(red) add $100 for DIF fan controller version C i will not sell these parts untill i sell the motor $1400 without FMIC and pipes $1300 without FMIC and pipes, R32 crossmember $1200 without FMIC and pipes, R32 crossmember, Slave cylinder, spark plugs, new water pump(i still have the stock one, i can put it on) $1000 just for the tranny, motor, and harness, ecu, turbo, manifold, down pipe, radiator & hoses, mounts, crossmember, down pipe, new valve cover gormets and gasket kit, new spark plugs. i will remove the new pumps and thermo, doesnt come with FMIC and pipes. or add $100 and new oil pump is yours $900 same as above but without harness and ecu willing to do some partial trade rear 5 lug swap for S13 SR parts, S15 T28, tomei manifold, greddy or tomei elbow, etc etc S13 SR swap or S14 SR swap S13 kouki tails. let me know what you got. ----------------------------------------------------------------------- N60 no pig tail $65 shipped + paypal Q45 with pig tail $85 shipped + paypal RB20 no pig tail broken tab(what you can do is shave all the tabs off and run a coupler) - $50 shipped + paypal DIF fan controller ver c - $105 shipped + paypal(new) wired up, but change plans. still got the box with instructions and stuff.. x2 ISIS 12" fans (new) just mounted - SOLD retail are $35 each not including shipping intrax lowering springs $70 with free stock struts and 1 kyb front strut good condition. pick up only for now RB20 OEM headgasket Brand new SOLD RB20 stock BOV with new gasket. $55 shipped + paypal S13 gauge cluster $40 shipped + paypal no bulbs and tach dont work(you can either put sohc or dohc) no cover unless i find it S14 steering rack bushing BNIB. just one, what you see is what you get. $15 shipped + paypal got a pop up light assembly(just the assembly) i will throw in the plastic cover if i find it. - $20 + shipping + paypal 4 lug hubs fronts and rears, one of the fronts have 1 broken stud $30 + shipping + paypal KA radiator with shroud and fan $25 or 30pack pick up only black primered pop up hood $40 or 2 30pack pick up only S13 seats, passenger side is perfect just a lil dirty - $40 or 2 30pack for both pick up only no pics yet. ignition and driver side cylinder with key. the ignition doesnt have that loop that goes under/around the steering colum to lock the ignition in place. you can use yours. $55 shipped + paypal fees 300zx e-brake cables, idk if its off a 2+0 or 2+2. how can you tell? $65 shipped OEM rear lower control arm, 1 is brand new just been sittin in shed, one is slightly used for like 30 miles on it. looking to get $190 + your old ones. their $200+brand new if i remember right their 260 new 1 stock pop up light bracket - $20 shipped
REVIEW Last edited by killer240; 09-09-2010 at 12:33 PM.. |
