Ka24de stuck in limp mode help please
So I have a 93 coupe. The previous owner rebuilt the ka24de and deleted egr. I got it and had it running fine for a while, went to get in it next day started up and idled at around 2000 but went down slighty after warmup. Took it for a drive and won't go past 2000rpm. Pulled codes and saw it said maf was bad. Which didn't make sense since worked the day before. So I replaced fuel pump, and maf. Still doing it. Checked my fuel filter and it's fine. Checked for vacuum leaks and there are none. Also when driving car if you take it out of gear after it bogs it just dies. What else could it be?
![]() Join Date: Jun 2006
Sounds like a issue ussually associated with a vaccume leak, but if you have already found that there wasnt one then check your MAf. Try unplugging the Maf and starting the car. If it has a hard time ideling your Maf is probably still ok. If it isnt and the car seems to run the same way, then you know that it probably isnt from your Maf and the problem is elsewhere. Hope this helps good luck.
I had the same issue a month ago, changed a few sensors and same issue, followed my wire that hooks up to my maf and it was broken
![]() Join Date: Jul 2013
bad MAF
replace it and get back with us. (as the above post states, check for an open or shorted wire(s) going to the MAF before replacing.
95 S14 se RB25DET 348whp
| bogging, die, fuel, ka24de, maf |
