Turn signal auto-cancel? [aftermarket hub & wheel]
So I can't get through inspection because my turn signal cancel doesn't work. Can I wire it up somehow? Replace some switch? Install something?
It's a Boss Steering Wheel Quick Disconnect Hub. Thanks |
![]() Join Date: Nov 2008
You dont have what you need pictured. Take the hub off, there are small holes on the back of your hub for a dow pin to go in and that strikes your turnsignal lever. I didnt have my dow pin as i already threw it away befor i realized what they were for. I then put a rivit in there but didnt pull back on the gun hard enough to break the pin out, then trimmed it to leingth.
