Closed Thread
Old 01-21-2011, 05:49 AM   #1
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Chase Bays Plug and Play Chassis Harnesses??!!
UPDATED PAGE 2
Just wanted to gather some interest. Its not 100% done (missing fuse/relay box)
Pricing we're unsure on still, haven't calculated time and material. Its a LOT of labor hours though. Very precise work like our engine harnesses. Ballpark cost will be $2,000+ for a full plug and play kit
Quick rundown of what this harness has, it would be 100% street legal
Headlights Low and Hi beam
Bumper Lights w/ turn signals
Side markers
Horn
Radiator Fan
Taillights w/ brake lights, reverse lights, and turn signals
Rear side markers
License plate lights
Armrest cigarette lighter (I will be replacing it with a USB port
Power Windows
Using FACTORY headlight switch on steering column
Push Button Start
Gauge Cluster
Radio with 4 speakers (speaker wiring not added in the pictures)
Sunroof
Windshield wiper with Hi and Lo functions
Engine harness
Anything not controlled by the OEM switches, we are looking into a touch screen switch board
Your thoughts?
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Chase Bays is offline
Old 01-21-2011, 08:32 AM   #2
don_bagz
don_bagz's Avatar
don_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to beholddon_bagz is a splendid one to behold
vq? maybe?
don_bagz is offline
Old 01-21-2011, 08:49 AM   #3
PoorMans180SX
PoorMans180SX's Avatar
You have peaked my interest with the touchscreen system. Please continue.
PoorMans180SX is offline
Old 01-21-2011, 10:00 AM   #4
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
I need a Chassis Harness so bad.... what if we send you our wiring (core discount)??
$2k is a bit steep... but we know you do great work.
What about custom hidden locations for the unit??
-Drew
MadScientist is offline
Old 01-21-2011, 12:19 PM   #5
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
Definitely interested but I can't afford it (at the moment). Will the harness 'tuck' away all the current fuse/relay boxes? What about pop-up head lights, you thinking about adding that in too? Keep up the good work guys! Love seeing your new products.
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline
Old 01-21-2011, 01:32 PM   #6
caglej
caglej is an unknown quantity at this point
I'd be down if we could delete certain features.
caglej is offline
Old 01-21-2011, 01:34 PM   #7
Chase Bays
Chase Bays's Avatar
This is chassis specific, not motor specific.
Im not sure if everyone is aware of this, if not you're about to learn. Most older ECU's and ALL stand alone/chipped ECU's (AEM, Apexi, Motec, etc) need 12volt, Ground, Starter signal, and Fuel pump to run. Thats it. Everything else is in the ECU. We all still need gauges and warning lights though so all that is in there. If you have a stand alone ECU this chassis harness will 100% work, doesn't matter what motor you have.
We would definitely need your core to use the plugs. We could send it back to you too but it will be missing about 10 or 20 plugs.
MadScientist and stinky_180...there is nothing stock used here except for plugs. We run our own relay/fusebox. We will be mounting it in the same spot as the stock fusebox behind the kick panel. This way you can unclip the fusebox cover on the kick panel just like stock if there is ever any issues
Here is one of our harnesses with the fusebox/relay board we will be using. All in one and compact. With an entire chassis harness it will more than likely be a 12 relay setup.
We can do pop up headlights, meaning we're capable. But it would take so long to do since there is 4 relays, a diode, and a timer. It would cost a LOT extra to do.
Old 01-21-2011, 01:35 PM   #8
Chase Bays
Chase Bays's Avatar
Old 01-21-2011, 02:34 PM   #9
MadScientist
what about the fuse box in the engine bay?
or did I miss something?
Options:
Mil- Spec connection / Non Mil-Spec
Old 01-21-2011, 04:28 PM   #10
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Oh baby, this turns me rock hard.
om3ga is offline
Old 01-21-2011, 04:31 PM   #11
om3ga
om3ga's Avatar
I think a touch screen switchboard that mounts in place of the stock HVAC unit would be superb.
om3ga is offline
Old 01-22-2011, 01:10 AM   #12
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
wow now thats what im talking about!
lewisfk is offline
Old 01-22-2011, 10:53 AM   #13
tcg5014
tcg5014 is an unknown quantity at this point
If you are willing to work with each buyer to delete and or add certain things I think this is great. I would say 2K is steep but if the price changes based on what all the harness does I would be more than willing to pay what it is worth to save me all that time and cursing. I will keep an eye on this.
tcg5014 is offline
Old 01-22-2011, 11:50 AM   #14
BoostinIX
BoostinIX's Avatar
BoostinIX is an unknown quantity at this point
Send a message via ICQ to BoostinIX Send a message via AIM to BoostinIX Send a message via MSN to BoostinIX Send a message via Yahoo to BoostinIX
Would certainly help people want to buy ripped-up shells. Having new wiring takes a huuuuuuuuge chunk of the horror out.
+1 for keeping us on the road :P
BoostinIX is offline
Old 01-22-2011, 01:27 PM   #15
roboticnissan
roboticnissan's Avatar
Fuccccccckkkk chasebays for mofo president.
roboticnissan is offline
Old 01-22-2011, 01:39 PM   #16
n8RPS13
n8RPS13's Avatar
n8RPS13 is an unknown quantity at this point
Chase I just went from 6 to MIDNIGHT!!!! hahaha. Awesome work bro!!! In the last two weeks you have released some awesome products and/or plans for awesome products. The price is kinda high but you get what you pay for! Will the engine harness come with this or will that be a separate order?
WASTED I AM!
n8RPS13 is offline
Old 01-22-2011, 07:15 PM   #17
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
amazing!!cant wait to see the finished product
project-D180 is offline
Old 01-22-2011, 09:33 PM   #18
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Feedback Score: 163 reviews
If anyone thinks this harness is expensive, then you don't even want to know what a touch screen setup to control the climate controls, windows, locks etc. would cost.
Chase, if you need first hand suggestions on the touch screen setup, give me a shout. My boy that owns Hybrid Audio Technologies uses one in his famous competition car... and it just so happens to be an S14. You literally slide your finger down the screen, in the appropriate place, to roll the window down etc. It also has full diagnosis, fuse and circuit status etc.
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline
Old 01-23-2011, 08:46 AM   #19
juiced305diesel
juiced305diesel is an unknown quantity at this point
I am very intrested... please let me know!
"Being a SSR wheel nude model is NOT easy, I just make it look like it is!"
juiced305diesel is offline
Old 01-23-2011, 09:03 AM   #20
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
That's fuckin pimp
1 year tour in Korea = no car. FML.
MisawaJason is offline
Old 01-23-2011, 10:02 AM   #21
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
This sounds pretty baller.
So what would be missing essentially?
This wasn't included in the OP.
FaLKoN240 is offline
Old 01-23-2011, 10:43 PM   #22
chiboy002
i honestly doubt many people on zilvia will put the money up for this, but its fucking awesome.
It'll be 100% oem functional right? Like everything that is there right now will be there when i'm done?
As well as does the fusebox move from the engine bay?
street dancer.
chiboy002 is offline
Old 01-25-2011, 03:51 PM   #23
jbballa9876
jbballa9876 is an unknown quantity at this point
I couldnt call myself interested in this one. The chassis harness is generally out of harms way and stays in good condition, if a wire were to ever fail on me i would just replace that wire. and not spend 2 grand for something that is not necessary to me.
But im sure plenty of potential customers would shell out the money so dont worry about people like me.
jbballa9876 is offline
Old 01-25-2011, 03:53 PM   #24
Edwin562
Edwin562's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
i would be interested... but well see until final product and price...
Edwin562 is offline
Old 01-25-2011, 04:20 PM   #25
surge s14
surge s14's Avatar
i would like to see what it looks like complete and installed before i can make a judgment decision on this one
i would love to remove all the crap i don't need
surge s14 is offline
Old 01-27-2011, 04:30 PM   #26
Chase Bays
Chase Bays's Avatar
Sorry for the delayed response. Kind of an INSANE week this week. Busy developing new 240 and EVO products.
Honestly, $2k is cheap. There is a lot of hours in this. There is a some companies (Sakata) that build these for $5k minimum.
We would be willing to work with the customer of course. Thanks!
Thank you sir! We're trying. No the engine harness would be separate.
PM'd!
I don't understand what you mean, whats missing?
Thanks! The objective of this harness is that we all don't run 50% to 75% of the crap that our cars come with, so this harness cuts out all that wiring with better material and better look. Anything you choose to keep will be fully functional however. all 3 fuseboxes are replaced with 1 fusebox that would sit in your kick panel area.
Coming tomorrow, finished install pictures.
Stay tuned!
Old 01-28-2011, 03:51 PM   #27
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
will it be substantially cheaper if it doesn't have the touch screen and wire up to the stock climate control!?
C-unit is offline
Old 02-01-2011, 01:55 PM   #28
Chase Bays
Chase Bays's Avatar
The touch screen would add cost, its still in development and probably wont be available for a while.
We will not be offering this harness with climate control.
Old 02-01-2011, 02:00 PM   #29
[email protected]
Advertiser
Mogli@9KRacing.com's Avatar
Trader Rating: (87)
Mogli@9KRacing.com is an unknown quantity at this point
Feedback Score: 87 reviews
Send a message via AIM to Mogli@9KRacing.com
looks nice, this thing destroys my painless kit
LIKE 9K Racing On Facebook for discount and product updates.
http://www.facebook.com/9KRacing
Contact 9K racing for any of your tuning or modifying needs.
Mogli@9KRacing.com is offline
Old 02-02-2011, 06:36 PM   #30
Chase Bays
Chase Bays's Avatar
hah yeah thats the objective. They have good stuff, not knocking them. Its more than you need usually and unloomed
Closed Thread
