![]() Join Date: Sep 2005
Used and available for pickup in Long Beach, CA. Will also ship.
Autometer oil pressure gauge, carbon fiber face w/ chrome ring. Comes with wiring and hose. - $30 pickup, $35 shipped
'93 Sileighty Last edited by middy; 07-16-2009 at 12:22 AM.. |
Intercooler core is 2.75" thick. Inlet and outlet are both 3" diameter. From edge of inlet to edge of outlet, intercooler is 31.75" long.
'93 Sileighty |
lol true but i need better cooling i get horrible heat soak with this gt30r and greddy m-spec intercooler.. maybe ill come by and check it out...where u located?
![]() Misty blu is coming 4 you! |
#13 | |
If you're talking about better charge air cooling, thinner is still better. Think about it. Air blowing across an intercooler heats up as it goes through the core. You can't cool somehting off by blowing hot air on it. The back half of a thick intercooler has hot air blowing across it, so half the intercooler doesn't work very well. Thicker only helps reduce the pressure drop across the intercooler, but with a core as big as this one, there won't be much pressure drop anyway. In this case, all a thicker core will do is make the intercooler less effective and heavier. -Dave |
| exhaust manifold, gauges, intercooler, turbo |
