Old 05-21-2011, 12:37 AM   #1
9am_S14
9am_S14 is an unknown quantity at this point
S14/s13? R32? Vlsd hella stuck
Alrite, So Ive wanted to do a vlsd swap in my 95 base model S14 for a while now and I finally picked one up.
Turns out its the complete wrong application and obviously wont just bolt right in.
I was told it was possibly a R32 vlsd but im not sure, all I know is it doesnt fit in my freakin subframe and i was told that it might even be an S13 LSD.
It has 4 mounting bolts on the back cover and 2 bushing mounts with small holes in the front (as pictured).
Ive heard of swapping covers from my open diff to make it bolt in,
but it looks like the front mounts are obviously much too small compared to the huge bushings bolted through the stock open diff in my car.
Can anyone tell me what kind of diff i have in the picture?
and what i can do to make it fit in my 4 lug base model s14?
Thanks a ton cause i aint drivin anywhere soon till i figure this beezie out
9am_S14 is offline   Reply With Quote
Old 05-21-2011, 11:36 AM   #2
Sileighty_85
Sileighty_85's Avatar
you should google S13 diff into S14 or somthing along those lines.
I will say it looks like an ABS HICAS S13 Diff
FYI those 5 bolt axle flanges wont work with the USDM S14 ones
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-21-2011, 11:09 PM   #3
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I just had a R32 GTS lsd swap into my S14. You need J30 axles and S13 front diff bolts. swapped the rear cover from my stock diff to the R32.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 05-21-2011, 11:55 PM   #4
BestOneLeft
BestOneLeft is an unknown quantity at this point
It does look like a s13 diff w/ ABS
If i remember correctly you should be ok with using the bolts from your s14 without the rubber bushings or with it used like a washer. And you need to swap the cover with your stock diff.
And you will need the j30 5 bolt axles.
BestOneLeft is offline   Reply With Quote
Old 05-25-2011, 04:09 PM   #5
McSlides
McSlides is an unknown quantity at this point
Whats the output shafts look like? It could be a Z32 diff. If thats the case all you need is the stock S14 (vlsd or not, although vlsd would be smart) diff cover and put the stock s14 output shafts in. It should bolt right up, mine did.
McSlides is offline   Reply With Quote
