sr20det red tp turn key swap for 300zx z32
Hey everyone for your consideration here it is .
My entire turn key swap its up for sale. Absolutely everything , true turn key swap , everything you need to have for your z to run and drive with sr20det red top. The car is still running and driving with the swap in it. Its a solid and reliable swap $7000 firm. If you are interested we can talk about absolutely everything done to the motor But the most important Isr t28 turbo 550cc injectors Tune ecu for 15psi with a z32 maf Isr intercooler Hks blow off S13 redtop With everything fresh as far as maintenance goes. If you have been fallowing my swap from the beginning you know what you’ll be getting for the price and is well worth it . Im working on making a detailed list of everything it has. $7000 firm here is the list of partsSwap Engine s13 red top •New oem seals intake , exhaust, front and rear mains, valve cover . •Upper , lower oil pan seals • water pump , thermostat and all sylicone water houses •aluminum pulleys •powder coated intake and value cover •fresh ngk plugs Engine up grades •isr hybrid t25/t8 turbo •550cc injectors •new turbo oil and cooler branded line •pulished intercooler pipping •isr Turbo down pipe with v band •isr intercooler •hks blow off valve •tune ecu by rsenthalpy with z32 mad ans 93 oct •koyorad for 240sx •greddy oil relocation plate Swap kit •Custom wire harness •mazwoxs trans adapter plate •modified transmission bell housing •modified x member •Dakota translator •nismo motor mounts •aluminio motor mount adapters •intercooler pipping •New battery stock z32 batery wire harness •all houses and fittings for p\s ![]() ![]() ![]() ![]() ![]() ![]() Last edited by izzy0007; 10-07-2019 at 04:37 PM.. |
![]() Join Date: Jun 2003
Trader Rating: (129)
you should strongly consider adding some pix
