first drag night
questions comment and concerns first the times.. i wish i could scan it but from the times you can tell im not lying...
r/t: .775 ( this was a red-green tree not full red yellow green tree) 60': 2.602 330: 7.158 1/8: 10.894 mph: 66.13 1000: 14.066 1/4: 16.758 mph: 83.30 This was my fastest of 5 runs, what would be the biggest cause of this slower time.? mods are as follows: intake, asp pulley, apexi n1 dual, short shift, agx, whiteline for suspension, and j30 lsd(is this the biggest problem?)17x7.5 5zigen 5zr with kumho tires. i shifted at almost 6500 give or take my guage is off a little so my first run i found the limit and then proceeded to shift at that point. is the differential not allowing me to get high enough in the rpm because of the ecu? or what.? Anyway, let me know.. i know its more for autoX becuase i have upgraded suspension and brakes and im pretty competitive at that.. but i expected better returns on the 1/4 mile times. JaY Last edited by Tricky1980; 09-20-2003 at 10:02 PM.. |
![]() Join Date: Jul 2001
Your 60' time is way high, you need to either practice a new way of launching or find a way to get more traction (are you having traction problems?) Once that 60' time comes closer to 2 seconds flat you should be in the 15's easily.
