KA sputtering at 4000 rpm!!
I've got a 1991 240 with a dohc ka and just freshly rebuilt with new internals. Now the only problem is that it hesitates to start and pops and spits from 1000 to 1500 rpm then smooths out fine until 4000 then sputters and wont go higher than 4000 rpm unless you feather the throttle. Anyone know what could be wrong?
The only thing not stock would be that i have a Z32 mass air flow sensor |
#8 | |
![]() Join Date: Aug 2003
Is the dist. new, rebuilt, or old? did you test the injectors? did you test the signal to the tps?
Drives a BRZ and is building a V6 S12 coupe. |
im suprised the car even runs with that MAF. you need to get a tune or an afc to calibrate that maf- clean the stock one and put it back on- you dont need a 300zx unit unless you are making better than 260hp. which you wont do without a turbo/ forced induction.
#13 | |
got a new stock MAF and now it runs butters. thanks for all the fast responses |
![]() Join Date: Oct 2008
i had the same problem, get a tune up done on your car and you should be fine, my problem was my spark plug wires, get some NGK's and its smooth sailing from there
