Typical my S13 wont start thread...
well well well, im back again... because my car likes to take huge amounts of shit all over me.
SO. here it goes. got in ma car couple days ago, turned the key, annndd nothing. Starter wasnt even turning. tried for a solid 5 minutes, and she finally started up. this is my daily, so , it needed to be fixed. First i went after my clutch safety switch. I noticed that it was a little damp all underneath the dash. Found my clutch cylinder to be leaking. I figured brake fluid ruined my switch. np. ill just order a new switch. Twenty bucks later, it still starts when it wants to. NEXT. I ordered a fresh clutch interlock relay from the dealership.. still starts when it wants... okay. Ive been driving like this for about 5 days now. I realized that it wont start in direct sunlight. If i park in the shade, she starts right up. I wanted to fix it properly before i attempt at bypassing the clutch switch. any pointers will be appreciated THANKS |
Testocore Advanced - Increases muscle growth naturally And Look Effective!
With negative effects such as low sex drive, energy, and inability to lose weight are just some of the signs that your testosterone levels need a boost. The general feeling of better well being alone is reason enough to turn to Testocore Advanced. You can find photographs of Testocore Advanced in several magazines that concentrate on Testocore Advanced but I'm not saying too much Testocore Advanced is good. They couldn't do this to save their soul. HOW DOES TESTOCORE ADVANCED ACHIEVE THIS? Risk-free-arrow HOW DO YOU KNOW YOUR TESTOSTERONE LEVELS ARE LOW? Simply read up on the Testocore Advanced Reviews and see for yourself just how effective it is and how it has improved the lives of so many men. That's the same old tale. Read about real men feeling strong and young again and pleasing their partners like they are in their 20's. A share of sharp people appreciate that. ENHANCE SEX DRIVE AND SEX FUNCTION BY GRADUALLY INCREASING TESTOSTERONE LEVELS WITH TESTOCORE ADVANCED! I was tickled pink to locate a Testocore Advanced like that. Unlike other supplements they boost your testosterone gradually and naturally thus not creating misbalance in your system. I'm not advocating that anyone stop using Testocore Advanced but also I'm trying to be honest with you. You don't have to miss my impractical ideas relating to Testocore Advanced.
click here to more information.======>> http://testocoreadvancedsite.co.uk/ |
#4 | |
![]() ![]() ![]() ![]() :nono :
"is that an old prelude"
![]() Join Date: Dec 2012
Is it 5 speed conversion? If it is check were your fuse box is were the starter signal from the auto trans was looped together, sometimes it gets loose if it wasnt saudered or linked together properly.
#8 | |
GM2 (SW/AW)
+1 battery in the back makes for weaker starting.
Check that starter wire. most likely loose along with the battery negative cable. It's starting when it wants to because when you turn your key it's getting a little connecting and basically accumulating signal.
![]() Join Date: Feb 2012
Trader Rating: (37)
So you replaced the ignition solenoid on the back of the ignition cylinder?
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
