| South Western States Arizona, California, Hawaii, and Nevada. |
exhuast leak or lifters??
hey wassup guys, there this ticking noise coming from the head by where the exhaust manifold is, idk if its the lifters or an exhaust leak, im missing 4 bolts on the exhaust manifold idk if that can cause an exhaust leak (im kinda a noob) another thing, i put some oil stabilizer in the motor and the ticking was gone, well it was still there but quieter, if anyone can come by and help me out ill spot you like 20 bux, thanx in advance... i live in the antelope valley area (661)
#2 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
if your oil level is full try revving it to 3k for like 1 min see if it helps
![]() Quote:
i went to go try your method but once i turned it on the sound got worse =( heres a video to show u
![]() YouTube - WP_000184.mp4 |
#4 | |
ooh yeah thats not lifters....thats something bad
did you drive your car really hard or starve it of oil before this happened? burnouts racing? um...yeah i cant give much more advice, sounds like the motor might be going out, could be the valves or inside the block? im not pro. i would take it to a mechanic
![]() Quote:
i did a complete tune up after i purchased it, and no i never abused it, the only reason y i got it was cuz i did a compression test and all of the cylinders came out good..
#6 | |
well i dont know what to tell you, how long ago did you buy the car?
and yes the 4 missing bolts will contribute to the car sounding like shit. but if there are 4 missing i would be more concerned that everything else might be half assed on the car... if thats how you bought it
![]() Quote:
ill say it been like 3 or 4 months since i got it, and when i got it the car sounded smooth i dont know why all of a sudden it just started happening, im taking it to a shop tomorrow to see whats going on with it, i hope it is just an exhaust leak and nothing really bad
thanx for the help tho man |
Totally sounds like an exhaust leak I had.
Depending on the material the gasket is made of, the exhaust pressure could've blown a small piece of the gasket off since it wasn't being held tightly between the head and the manifold. |
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
you can smell fumes from your exhaust manifold if anything? idkkk but good luck!
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! ![]() #/f/private-sellers/...meistah21.html |
![]() Join Date: Aug 2010
Trader Rating: (38)
does it go away after its been running for awhile? i have a leak in my exhaust mani too, but its no where near as bad as that.
its most likely an exhaust leak tho if u have 4 bolts missing haha they're there for a reason ![]() best way to tell is by using a smoke machine tho. if u know anyone with one, or a shop or something (maybe ur local school with an auto department) id recommend that. however if u cant do that, take a rubber hose, and use it like a stethoscope. put one side up to the exhaust mani and the other side up to ur ear. move it around and u should be able to find a leak using that method as well. all in all, get some new bolts for it lol |
#14 | |
its most likely an exhaust leak, and the gasket is probably shot...
and make sure you do fix the engine light
![]() Quote:
#23 |
![]() Join Date: Aug 2005
-edit-
Deleted a somewhat condescending approach to explain why missing bolts can cause the leak. It looks Hartig already nailed it on the head.
This is my clever and witty signature. |
#27 | |
go to the junkyard, or look on zilvia. if you want to spend less.
you can get them at the dealer just spending more
![]() Quote:
#30 | |
well if you only need 4, and that will solve the problem with quality brand new never used bolts.
sometimes its worth coughing up 12 bucks... ive spend 50 bucks on stuff a few times and got nothing out of it. i spent 200 on something and got screwed i spent 400 and ..... so on and so on. 12 bucks is like a penny to me now adays.... not because im rich, because when it comes to my car and doing it right. you always end up spending more in the long run if you cheap out on certain things. but in this case it would just be time you would be losing, and if you have time then keep searching for bolts that are cheap
![]() Quote:
