Closed Thread
Old 12-20-2008, 11:45 AM   #1
Hawaiian240
Hawaiian240's Avatar
Hawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud ofHawaiian240 has much to be proud of
s13 1991 S13 parts. DIN pocket, tension rods, spacers, front calipers
All prices do not include shipping unless otherwise stated. I accept cash or Paypal only.
I am in the Goose Creek/ Charleston area.
S13 DIN pocket $10.00
Some suspension stuff
S13 OEM tension rods $10.00.
Comes with Energy Suspension bushings(pictured), NOT installed!
OEM rubber bushings are shot
S13 OEM Rear Upper Control Arms $10.00.
S13 OEM Traction Rods $10.00.
25mm/ 4 x 114.3 spacers, brand unknown. Comes with nuts and hubcentric rings for S13. Bought this from another Zilvian a while back. $50.00
S13 OEM front caliper setup. Calipers probably need to be rebuilt, comes with everything pictured. $15.00
S13 USDM steering wheel 10.00
S13 Instrument Cluster bezel/trim w/ following switches: hazards, rear window defroster, dimmer lights(doesn't work well) and coin holder <<<<<<<<SOLD>>>>>>>>>>
KA24DE pistons from a '95 S14 w/78k miles. 20.00
Sides of skirts have some wear.
Ring lands are still good, comes with original rings too HAHA!
Comes with pins, but 2 of the retaining clips are missing.
Tops
Bottom
KA24DE crank girdle, NO BOLTS. I have 2 of these. No scoring on the journals. 20.00 each
If it's good for something............ a KA24DE crank with pully key groove damaged(see 2nd pic). Journals are still good but NO KEY! FREE!! You just pay for shipping, or come and pick it up!
Maybe you can use it as a paper weight or something!!
Fixable?????
KA24DE bare block. 50.00
Decked, honed, tapped for turbo oil(supply and drain, explained below) and cleaned at S&R machine shop(Summerville, SC).
Light surface rust on machined surfaces. Was going to use this for a rebuild, but rebuilding my other block instead.
Oil supply tap at oil pump journal. 1/4" NPT
Oil drain tap(drivers side just forward of bellhousing) 1/4" NPT.
S13 output shafts, 6 bolt. DOES NOT COME WITH BOLTS pictured!! 20.00
Vortech Engineering 6:1 FMU. 75.00
New at Summit for 167.95!
Setup for Ford mustang with 36 lb/hr injectors.
You can order different shims(from Vortech) to change ratio.
Comes with mounting bracket, about 24" hoses with weird fittings that I have not seen before!
Hoses
Weird fittings!
Have more stuff to get rid of, will post those later.
For Sale threads:
#/f/sale-items/33286...tons-pics.html
Review Thread:
#/f/private-sellers/...-chhheeee.html
TRADER RATING:
#/f/traderratings.html?u=66301
Hawaiian240 is offline
Old 12-21-2008, 02:22 PM   #2
Hawaiian240
Nobody needs a DIN pocket or 25mm spacers?? 1st BUMP!
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-01-2009, 07:30 AM   #3
Hawaiian240
s13
Added instrument cluster bezel and S13 steering wheel. HAPPY NEW YEAR!
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-01-2009, 03:48 PM   #4
k0uki
Trader Rating: (47)
k0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfectionk0uki is close to perfection
Feedback Score: 47 reviews
wanna do 20 shipped for the instrument cluster bezel
k0uki is offline
Old 01-01-2009, 05:48 PM   #5
Hawaiian240
s13
Sounds good, I can do that. PM sent.
For Sale threads:
Review Thread:
TRADER RATING:
Old 01-08-2009, 03:15 PM   #6
Hawaiian240
s13
Added Vortech FMU, OEM RUCA, traction rods, tension rods, S13 open diff output shafts, and KA24DE block and parts.
For Sale threads:
Review Thread:
TRADER RATING:
Closed Thread
