![]() Join Date: Dec 2010
canada: cheap gtst/z32 brakes. everything except rear calipers
going a different direction so im selling my brake setup. its off a skyline gtst which i believe is the same as 30mm z brakes. selling everything except the rear calipers. fronts just bolt on
includes: - front 30mm calipers - ams stainless brake lines front and rear - rear knuckles with ES poly bushings pressed in and drum brake setup (hicas tie rod removed and bushing pressed in) - rear drum brake setup once again does NOT include rear calipers, im keeping them. it is also not necessary to use the rear knuckles but the drum setup is attached to them. not including 5 lug hubs either. looking to get 275+ shipping for everything. make offers, i have no use for any of the stuff. pics: other knuckle isnt pictured because its still on the car, along with the rear brake lines (but they look the same) Last edited by JaredP; 02-13-2012 at 01:04 AM.. |
