How often to change fluids?
For a stock car besides z32 front brakes that gets mostly city driving on it how often is it recommended to change fluids: brake, clutch, transmission, vlsd diff, AC free-on, antifreeze?
z32 front brakes, spl tc rods |
Just change fluids before they get too dirty.
Don't forget power steering. Also READ the FSM, you don't wanna use power steering fluid for the power steering, lol.
Rock wha U jock and don't talk if U ain't got!!
well, i had been doing transmission fluid every 60K according to the fsm but after the second time they said there was a lot of metallic shavings that came out of the transmission when they dumped the fluid. Thats when I got a new transmission because they said the bearings were bad and he told me to replace the fluid every 30K. I don't think the fsm says when to replace some of the fluids such as brake and clutch fluid. It just says inspect every so many miles so thats why i ask. For fluids I plan on using amsoil GL4 75w90 for the tranny and for the diff probably amsoil sever gear ep 75W90. I know the fsm says to use dot 3 for brake and clutch fluid. I have used valvoline synthetic dot 4 or 5 for the brakes so should I continue using that or is it possible to switch back to dot 3 (which I assume is not synthetic) for the brakes?
#11 | |
![]() Join Date: Apr 2006
Brake and clutch ideally once a year Dont use Valvoline its crap use Castrol instead
Project cars: "Fail to plan, plan to fail"
![]() Join Date: Jan 2009
Trader Rating: (25)
Exactly. I forgot about his a while back and put PS fluid in. My pump whined quite loudly until I flushed it and put ATF in. From what I understand, it can fuck up your power steering system
