kade t3 manifold , sohc turbo kit! r32 lights, s14 speed sensor/cas/fog
This is my ongoing for sale thread. Check it out I own a fender roller and rent the tool for goods or cash, pm if interested. (I do NOT provide the actual service for liability reasons if your not happy and just for time reasons) $50 for tool with $200 refundable deposit once returned in the same shape it left, 7 day rental. Everything is up for offers unless otherwise specified. ka24de t3 turbo manifold and elbow Started life as an equal length t25 mani of unknown origin. Dentsport chopped the flange and welded a t3 flange on then did some reinforcements, legit. T3 5 bolt elbow with integrated internal wastegate, connects to sr20 downpipe. Sold as a set for your ka-t $125 Greddy hot pipe with greddy type rs flange Purchased from cip years ago for 100+. its scratched but could be refinished. Don't have couplers at this time. $40 my old sohc turbo setup. Less than 500 miles on the whole thing, it made it to a meet at most while building my car. I pulled the head for leaky valve stems and now am building a new setup. I was getting 10psi by 3krpm on this! This one includes (individually priced just for tallying): *No longer available top mount nizzyx.com manifold with upgraded helicoil threads (stock was terrible) and a perfect full port polish job (needed it bad). After it was ceramic coated inside and out. REAL "need a license to" ceramic not autozone paint. $450 *TRUE Garret t3/t4 46 trim .48 ar turbo with ceramic coated turbine housing and mild port work both compressor and turbine side. 500 miles since fresh build and assembly, all garret parts inside I rebuilt it myself. Includes barbs for coolant lines $400 * Custom 2.5in elbow with bmcrace beefy flanges that connect to sr downpipe. $80 * -3an feed line and restrictor and adapter to turbo $30 * Drain adapter and 5/8 hose $20 * Includes screamer pipe for tial 38mm wastegate if you want it. WG not included I am using it. $35 Will not part setup, well over $1000 worth looking for $800 obo. Will swap on 50 trim wheel for buyer if requested. Pics from right when I installed, recent on request. http://i4.photobucket.com/albums/y12...e/DSCN2308.jpg Garret t04 50 trim wheel and compressor housing Was going to go bigger on the other turbo, changed my mind. $75 R32 gt-r headlights immaculate off the showroom condition, pics on request. $160 s14 CAS sensor $25. S14 factory SE fog light no cracks or scratches, good condition.Glass surface is very pitted which is expected based on age, but it doesn't compromise light output as far as I can see. Like a bonehead I dropped the driver side on concrete so just got a passenger to sell now. $15 picked up S14 AT speed sensor $25 KA OEM flywheel, generic pressure plate, organic disc clutch $50, surface rust is very light. Stock infinity j30 corner lamp pair. Looks like new condition(might even be new). make offers http://i4.photobucket.com/albums/y126/t ... CN1471.jpg http://s4.photobucket.com/albums/y126/t ... z/forsale/ pics in my photobucket LOCAL PICKUP ONLY BELOW. WILL NOT SHIP, I repeat WILL NOT SHIP BELOW s14 header Used, dunno who makes it? beautiful welds good condition. Made from stainless but not 316 so brown but not gonna rust out. $75 Drift tires! Michelin pilot sport 235/45-17 Tires from my last rim purchase from b13-t. Chunking off sidewall (From error when mounting) but no visible cord and not to the bead. light camber wear on 1 tire, maybe half tread life - decent. Was told they hold air and side damage is no problem at an event (he said he would run them). http://i4.photobucket.com/albums/y12...ale/tire21.jpg http://i4.photobucket.com/albums/y12...ale/tire22.jpg http://i4.photobucket.com/albums/y12...ale/tire23.jpg http://i4.photobucket.com/albums/y12...ale/tire41.jpg http://i4.photobucket.com/albums/y12...ale/tire42.jpg $20 for the pair. S14 Rear SE seats $20 My wanted list I accept trade of: right now just dirt cheap aftermarket sr turbo elbow Another wideband MAYBE |
can you send me some pics please 203-627-6248 of the headlights or email them to [email protected]
Here are some pics I just took now
drain and feed line are not in picture, I left them in a buddy's car going to a swap meet and have to go grab them. You can see all the fittings etc though Turbo absolutely is tight and clean it was JUST rebuilt. Might look wet because I squirted it all down with heavy oil before storing to keep the seals fresh and guts rust free. Spins like cake, no contact at any point. r32 lights you can see even come with electrical pigtails and harness to make it even easier, check out how legit they look! Also have an OEM sr t25 elbow that was ceramic coated with cbx piston top ceramic (legit) $15+sh |
