#2791 |
![]() Join Date: Dec 2004
Trader Rating: (58)
I'm certainly no engineer, but I'm curious to having that snap ring so 'high' above the seat being a possible issue.
#2792 |
If I remember correctly, the Megan balljoint shank is about the same length as the stock one, so it doesn't do anything.
Btw, does anyone have experience with Dmax tie rod ends? I was thinking about buying them, they are going for 100 bucks at 240sxmotoring. ![]() |
#2793 |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
Cody the snap ring, appears to be I'n the identical location as the stock one... And even if it was higher the stock one does not touch the lower control arm either. So I would assume to be fine... Will see what other think
NEED Bolt kits for your car? |
#2794 | |
the same press fit as the stock one? Measure the taper? S13 or S14 or something else? Those would be my concerns. Good lead though. |
#2795 |
Trader Rating: (82)
I don't have a measuring device... Before I install the other side I'm going to measure it maybe it's different
#2796 |
where can i find more info? i want to do this to my knuckles. what does it take to weld something this thick?
#2797 |
![]() Join Date: Nov 2005
Aasbo's Scion tC knuckle.
![]() Hmmmm, it uses an S-chassis steering rack, is this an s-chassis knuckle? They don't say specifically, but it looks like it to me: ![]() That's a pretty trick setup, bolting to the brake caliper bracket, and the knuckle looks to be machined flat (where the steering arm normall starts) and drilled for another bolt, with the steering arm wrapping around the ball joint. FLCA's are pretty cool too. ![]() Last edited by PoorMans180SX; 06-09-2011 at 12:20 PM.. |
#2801 | |
Trader Rating: (58)
I was thinking about that there....red line is the base....green is the stock stap ring....orange the new. Don't you want the snap ring close to the LCA as possible?
#2802 |
![]() Join Date: Apr 2004
That thing doesn't look like it does dick anyway, maybe 1/8" of RC correction max... and yes, you want the snap ring to keep the balljoint from moving.
#2803 |
I finally got my hands on some suspension modeling software and just did the calcs. Even with the best of the best ball joints, the $275 moonface, you're only reducing the roll couple from 12.125" to 10.625". For a whopping gain of 1.5". Big deal.
Post # 385 if you're interested #/f/tech-talk/147301...to-pan-13.html
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: #/f/tech-talk/147301...d-gto-pan.html |
#2804 |
50mm rc corrected hubs raised my rc by 110mm.
I have since raised the front end up so I have pretty good roll centre. I wouldn't bother with gay balljoints lol
[SIGPIC][/SIGPIC] |
#2805 | |
![]() Join Date: Dec 2003
#2807 |
SPL carries some nice ones. So does Megan.
#2809 |
yeah, there is that... So like I said, SPL makes some nice ones.
#2810 |
hey guys new to this forum, kinda well i read through this thready about 4 times now. twice after taking to my steering setup. done some mods, moved rack forward 30 and up 30mm, along with some tie rod rose joint spaced down 20mm. cut and lenghten the fron LCA's between the caster and out ball joint by 40mm, as well as Steering rack spacers washers. 10mm as well as some Custom Hubs that i managed to copy off a mate, i did make a few small tweeks to the jigs, well here is the result. i still need to get it out ont a flat piece of concrete and mark out the angles of turn each wheel at say 1/4 turn 1/2 turn, 3/4 turn and full lock to make sure the trailing wheel at no point has more angle then the leading as the trailing wheel does look pretty extreme.
and a few of it in action. |
#2811 |
You moved the steering 50mm without changing the location of the LCA? Sounds like bumpsteer city. Please post pics of the actual suspension parts!
Yes, it does look like you have zero or possibly negative ackerman, but it's hard to tell from pictures. |
#2812 |
Don't bother with the generic tie rods Razi. They all look the same, and if that's the case, they only offer about 16mm of adjustment over stock with same articulation. Splurge for SPL and get better rod ends, more articulation, and more adjustment.
#2813 |
If you had room to move your steering rack up 30mm than that means you had room to lower your engine 30mm. Lowering the engine/trans and making the height correctio at the spindle with spacers would pay off in handling department big time.
#2814 | |
I don't mind coughing up an extra 100, but don't I also need to buy Z33 inner rods to make em work with the stock knuckles? Is that because the threads on the S14 inner rods don't go deep enough? Or can I trim a bit off the S14 inner rods and make them work with the SPL? |
#2815 |
![]() Join Date: Apr 2009
OK everyone I need inner tie rod suggestions, right now I have pbm knuckles with s14 lower control arms on an s13 with moog outers and back arnley inners. The s14 inners dont have a very long rack side so that makes me a bit nervous with the spacers and Im ok for threads on the outside but im only on the first hole in the knuckles not the second one. what else do I have for options I am not having any luck finding ikeya formula ones.
#2816 | |
A local guy just bought them and loves 'em. |
#2817 |
![]() Join Date: Mar 2009
With all this angle people are making does anyone care about mechanic jacking? seems to be a big tuning point on karts and race cars...
CHOMPONWHAT? |
#2818 |
well i just measure up my steering angles. turns out i've gone the other way now and have alot more negitive ackerman man, now, so gona put a stock engine xmember back in and slowly adjust rack position till i get to the 0 point. or as close to it as i can
#2819 |
PBM is out of stock and is doing a little reworking on there inners last I talked to them. I was on the wait list for a long time but then things changed up a bit.
#2820 |
from what I have noticed if you run enough static camber and proper caster settings to keep a somewhat flat contact patch at angle it is not so bad. I also heard that alot of S13 drift cars are having good results from running reverse rake. Not to mention that I would think in grip racing situations it causes alot more instabilty than in drifting. But that is just my uneducated look at things I could be completely off.
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
