>>>>>exedy carbon clutches<<<<<
![]() ![]() Got some deals on Exedy Carbon clutches. Single , double, and triple plates. These are for the people pushing high HP in their sr20det. The flagship model of EXEDY Racing Clutches: the carbon steel multi plate clutches. These clutches are light in weight, durable, and resilient to high heat, contributing to an improvement in track times. These complete bolt on designs require no additional modifications to the vehicle. The carbon materials are baked at more than 2000 degrees celsius which allows the the carbon material to dissipate heat far better than conventional metallic material. Specs Number of Discs: Single, Double, or Triple Spring Damper Discs: Solid Center Disc Push / Pull: Push Type Disc Outer Diameter: 200mm Spline Teeth / Major Diameter: 24T / 25.6 mm Single disc are $1410.95 Double disc are $2120.74 Triple disc are $2709.83 Get them here --->clutch or hit me up on PM. |
