| South Western States Arizona, California, Hawaii, and Nevada. |
![]() Join Date: Jun 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Throttle body rebuild service?
Hey just seeing if any of you guys know of a throttle body rebuilding shop in SoCal? I need to rebuild my n15 throttle body because it?s leaking boost. Thanks!
![]() lexus baby |
Don't know them directly but a quick google search turned this up;
https://socalporting.com/our-service...-body-porting/ If they can port them, they should be able to rebuild them as well. There are quite a few shops out there that do mail-in as well. http://maxbore.com/ That guy has a pretty good reputation and I've been looking into sending my KA throttle body his way when I run out of stuff to mess with on my S14. I'd call and talk to them about what you want done but I don't imagine either would have any trouble taking care of the seals. Good luck, keep us posted. |
![]() Join Date: Mar 2008
Just take it apart, measure the shaft diameter and order the seals. Make sure to orient the seals for boost. Some NA tb's like the KA have the seals flipped for vacuum.
I can't remember, but it was a site that sold all kinds of seals for many applications. Maybe McMaster Carr. Get the measurements for the shaft and the outer sleeves they are pressed in to and you can find the right ones you need. Make sure they are oil & heat resistant and rated for high pressure. The factory seals are squishy and weak and should be replaced with strong seals with the metal jacket and spring. They look like tiny front main seals.
#8 | |
![]() lexus baby |
