OMNOMNOMNOM
![]() Join Date: Dec 2000
Wanted Items Rules and Guidelines
This section will be limited to a 30 day post before it disappears from this section, although you can still find it if you do a search. This will be to keep everything current. If you don’t find your item in those 30 days then please post your needed item again. Do not bump your item more then one time. If it is bumped two times your post will be deleted. Topics will be moved/locked at moderators discretion. Signatures Signatures must not be more then 400x200 pixels. Failure you follow these rules will result in your signature being removed without notice. Depending on file size of the image it will be removed from your profile without notice. |
