Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 09-04-2013, 04:44 PM   #1
Nevyn04
Nevyn04 is an unknown quantity at this point
Z31 will not run
Just got an 87 300zx turbo less than a month ago. was running great. About two weeks ago it started stuttering a bit at around 4000 rpm. but power came back at about 5000 rpm. Then, just over a week ago, halfway through my hour commute to work, it began stuttering really bad. It continued until it died. I could start it and it would idle rough until again, it died. Then it ran fine. For a minute. Had to have it towed back to my house. Rented a fuel pressure gauge and it is running about 40psi. for the few seconds it runs that is. Plugs and wires are new. Distributor cap is new. TPS seems to be getting the right voltage. Car runs exactly the same whether the MAF is plugged in or not. I am stumped. And extremely irritated. Anyone know what this can be? It is my only mode of transportation, i need it fixed asap.
Thanks.
Nevyn04 is offline   Reply With Quote
Old 09-04-2013, 10:14 PM   #2
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
Do this:
XenonZcar.com Z31 ECU Diagnostics
and see what you get.
Sounds like it might be the crank angle sensor maybe?
z31 Lovin'
http://imageshack.us/a/img337/2396/lowerit.jpg
DeleriousZ is offline   Reply With Quote
Old 09-06-2013, 04:56 PM   #3
Nevyn04
ran diagnostic.
Codes
12: Air flow sensor
34etonation Sensor
51: Not shown in xenons code list
Replaced Air flow sensor. Still does not run. I'm lucky if it starts...
Any other ideas? Would detonation sensor cause this?
Old 09-07-2013, 01:18 PM   #4
Nevyn04
Was about to replace distributor based on advice from a mechanic friend. I noticed the bolt that allows you to adjust the distributor was slightly loose and you could see where the distributor used to be. So i readjusted it and the car started and idled perfectly. But would die as soon as it was under load. So replaced the rotor. Perfect. Car ran and drove good as new.
Took it around the block and it died. Would not restart. removed the cap and realized the new rotor was slightly bigger than the old one and was gouging into the caps contacts. So bought a new cap to match the rotor, both of which are apparently for my car according to autozone, and the vehicle will not start.
I feel like i'm looking in the right area now but not sure where to go from here.
Help?
Old 09-09-2013, 08:38 AM   #5
DeleriousZ
DeleriousZ's Avatar
Try swapping the distributor for a known good one. The crank angle sensor is housed within the dist and can cause serious headaches if it's gone or going bad.
z31 Lovin'
Old 09-12-2013, 06:15 AM   #6
Nevyn04
Alright. Replaced the rotor because the old one looked a bit worn. car ran great after that except the rotor was a little longer than the original and hit the contacts. Installed a new cap. Then all of a sudden no longer got spark. Replaced ignition coil. Still no spark. So came to the same conclusion, it had to be the crank sensor. Replaced the distributor and now runs great.
Only issue i have now is a stutter at about 4k rpm. This only occurs at WOT. Any suggestions?
Old 09-19-2013, 09:01 AM   #7
bleakdragonmage
bleakdragonmage's Avatar
bleakdragonmage is an unknown quantity at this point
How bad of a stutter?? Does it clear up after 4k. Does it happen while free revving or under load.
My guess is that its the plug wires.
1988 570zx SS Edition
bleakdragonmage is offline   Reply With Quote
