03-23-2008, 02:13 PM | #1 |
blueish white smoke
i searched and didnt find anything pertaining to my scenario
out of the exhaust during a cold start and warming up, smoke is billowing out, cant tell what it smells like, my nose is clogged from a cold right now, once the car is warmed up i will drive it and it i will smoke for about one minute then it will stop, just had head work done, bc cams, springs, retainers and new valve seals and cometic headgasket head work was done about 3 weeks ago and it started smoking about a week ago, its worse than a week ago could this be the valve seals, piston rings, headgasket? thanks |
03-23-2008, 06:08 PM | #3 |
sounds like there's some sort of clearance issue with the cylinders and the walls. as metal heats up it expands which may explain why the smoke goes away after it's been thoroughly warmed up. Correct me if i'm wrong.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
03-23-2008, 06:11 PM | #4 |
youre burning oil. your piston rings might be fukkked
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
03-23-2008, 06:18 PM | #5 |
How did you search... by posting this thread?
That by the way, is the same as like 15 other threads Blue means oil White means water/coolant black means gas which means.... you are burning oil so... http://www.zilvia.net/f/search.php
"I am Norwegian, and are not familiar with your urban words :P" |
