Old 07-30-2001, 01:04 AM   #1
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
I am looking at a s15 sr20det engine and understand how most of it works.  I just don't know what vvtc is.  I know after Honda let out VTEC, with 3 cam lobes, and then toyota and Porsche come out with variable valve timing methods.
I just wanna know how Nissan's VVTC works.
Thanks,
-Jeff
Jeff240sx is offline   Reply With Quote
Old 07-30-2001, 01:32 AM   #2
Guest
Posts: n/a
The i-VTEC system combines VTEC (Variable Valve Timing and Lift Electronic Control) technology with an innovative new camshaft phase control system called VTC (Variable Timing Control).
VTC uses a spool valve that directs high-pressure oil to chambers inside the intake cam's drive sprocket that allows for continuous adjustment of the intake camshaft's phase (position relative to the crankshaft) over a range of +/- 25 degrees (advance or retard). A separate VTC electronic control unit monitors RPM, camshaft and throttle position, ignition timing and engine exhaust condition to determine the necessary cam phase adjustments.
thats honda style. i guess its the same style with nissan
