Toronto - Clean Built 97 SR S14 Kouki
Hi All,
Entertaining selling my car since I've owned it for like 5 years and rarely driven it. Spec list is below don't mind selling to the US. Looking for 16.5k USD or 21k CAD. OBO everything is negotiable Any constructive criticism is welcomed. Photos are in the link https://imgur.com/a/nzWYbMj https://imgur.com/a/nzWYbMj Car will come with a bunch of parts if asking price is met. Extra LCA, Z32 ebrake setup, bunch of oem components(stock Kouki tails, Stock painted mirrors etc), a cage as well(not sure if it was for this car). Only cons right now - - Speedo is not working after CD009 Swap (everything is ready just need to calibrate the Dakota Digital Converter, I will have it done this spring) - Proper dyno tune since it is on a street tune on 14.5psi wastegate pressure and I keep changing things without driving the car. - I will be keeping the Vertex Steering wheel and seats. You will be getting a Nardi in place of it and stock seats. 1997 Kouki 240sx Slicktop 125xxx kms no rust!! Porsche 993 Midnight Blue Metallic Paint Origin Lab Aggressive Kit/Version Select Kit Custom Bash Bars F/R Chargespeed +20mm front fenders DMAX Trunk Spoiler GK Tech mirrors Megan Carbon roof spoiler Rays Gramlights 57DR with zestinos17x9+12 (225/40R17) 18x9.5+12(235/40R18) VIS Kouki Carbon Hood Origin Labo Carbon front canards S14 SR20DET Homemade Engine mounts to move the engine 2 inches away from Masterbrake cylinder CP Pistons Manley H-Beam Rods Apexi HG HKS 264 cams 740cc Injectors AEM FPR and Gauge 255lph Fuel pump Larger 60mm throttle body 350Z coilpack swap (needs to be installed) Greddy Lower oilpan with Greddy magnetic drain plug Centerline Top Mount Manifold Tial F38mm wastegate GTX3076r with T3 Vband exh housing Oil Catch can with AN lines Oil Cooler New Koyo Radiator with Flex-a-lite Fans Apexi GT exhaust Apexi PFC D-Jetro Rare OEM Nissan Strut brace Rear strut brace and pillar brace ARC Rad Cap Greddy/Trust Oil cap CD009 Autotech Adapter GKTech Shifter relocation and crossmember Machined CD009 with 90000kms on it Megan stiffened Transmission mount Custom Aluminum one piece driveshaft ACT clutch and pressure plate Fidanza lightweight Flywheel Dakota Digital converter box for Speedo Front 4-pot STI Brembos and 350Z slotted rotors Techno Toy Tuning Extended LCA PBM Inner Tie Rods GKtech Outter Tie rod GKtech Steering rack offset bushings Tein Type HE Drift Coilovers Front and rear multilink Greddy Exh, Oil Temp, Oil Press Gauges and Sensors AEM TruBoost AEM AFR Pioneer Double Din with new speakers NRG quick release and hub Last edited by Brodmon; 03-10-2020 at 01:45 PM.. |
So this car was once titled in North America? Because if not it’s not as easy as just paying taxes and bringing it across. I tried this with a 97 BMW M3. Even though we got the same car here in the states, they still needed a letter of compliance from the manufacturer.
#8 | |
![]() Join Date: Jan 2013
