01-28-2012, 03:02 PM | #31 | |
01-30-2012, 03:48 PM | #32 |
so i recorded a video of how it acts. so if someone can help me out or something. 240sx Problem - YouTube
01-31-2012, 02:28 AM | #33 | |
If you had an AFR gauge and a wideband sensor, you could see what your fueling looks like, but you dont have that and it will be cheaper to just change the fuel pump and filter. I cant hear the sound of the video (i am at work) but your idle speed looks awfully low to me. Is it usually that low on KA engines ? If it can keep that idle speed, there should be no boost leak (it either causes high idle or engine stall). If your fuel pump is still the oem one, start by replacing it and the fuel filter. Also check your temp sensor, idle should be accelerated when cold and it does not look accelerated at all. |
