S13 ebrake cable options for stock rear calipers
I've searched around to see if there are any options other than stock cables for the rear calipers and I haven't come up with anything conclusive. Most posts are either about z32 caliper swaps or so old that S13 cables weren't discontinued or over $100 each on eBay.
So, is there anything that will work on an S13 that you can still buy new (even with some kind of adapter bracket)? I'd like to replace the left and right, if not the front/handle cable too. If there's nothing, has anyone tried rebuilding the cables? Fwiw my sleeves and brackets are in good shape, the cables are just stretched out. |
![]() Join Date: Mar 2009
I would assume that a good motorcycle shop should be able to put a new cable inside of the existing sleeve/hardware.
![]() Join Date: Jun 2003
Trader Rating: (129)
I have a set of stock cables that came off a bone stock s13. zero modifications, 130k miles. let me know if youre interested.
