Old 07-22-2011, 09:25 PM   #1
ra21lover
ra21lover is an unknown quantity at this point
help with xxr 527's in front of my s14!!!!!!
I was excited today to mount my wheels on my s14 i had bought the xxr 527 17x9.75 all the way around well anways i ve been reading u have to put a 5mm spacer in the fronts which i did but it hits my coilovers i am running megan streets i dont know what to do....getting frustrated rim the inner is hitting the collars....any input please....
ra21lover is offline   Reply With Quote
Old 07-22-2011, 10:05 PM   #2
WERDdabuilder
WERDdabuilder's Avatar
WERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfectionWERDdabuilder is close to perfection
bigger spacer?
When the power of love overcomes the love of power, the world will know peace
WERDdabuilder is offline   Reply With Quote
Old 07-22-2011, 10:08 PM   #3
ra21lover
Originally Posted by WERDdabuilder View Post
bigger spacer?
i tried stacking 3 mm spacer on top so = 8mm no luck iam running out of tread on my studs unless i extend them??? i see the s14 have no problems with what am i doing wrong>>>
Old 07-22-2011, 10:31 PM   #4
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
maybe you got the wrong offset? hate to break it to you but you're probably going have to get longer studs and bigger spacers if you're still rubbing the coils.
upsdude is offline   Reply With Quote
Old 07-22-2011, 10:33 PM   #5
SecretS13
SecretS13's Avatar
SecretS13 is an unknown quantity at this point
loosen the coil where is goes onto the knuckle, where the long bolts go in, pull on the rotor or hub towards u and tighten the bolts down.
hope that kinda makes sense, whats the offset? iam running 18x10 +22 up front and put a 15mm spacer and it still rubbed, losened the bolts pulled the wheel out and it doesnt rub anymore
SecretS13 is offline   Reply With Quote
Old 07-22-2011, 10:34 PM   #6
rob22
rob22's Avatar
Trader Rating: (50)
rob22 is an unknown quantity at this point
Feedback Score: 50 reviews
did you get the 17x9.75+20?
you shouldnt be having a problem if you did.
i had 17x9 xxr 522+25 for about a week. i didnt have money for spacers or studs so i used small washers and i cleared.
wtb s14 roof wing/spoiler! pm me
rob22 is offline   Reply With Quote
Old 07-22-2011, 10:44 PM   #7
ra21lover
yup i did 17x9.75 plus 25....does it matter if its 4 lugger???
Old 07-22-2011, 10:48 PM   #8
SecretS13
SecretS13's Avatar
Old 07-22-2011, 10:49 PM   #9
ra21lover
Originally Posted by SecretS13 View Post
do what i said
okay thanks.......................camber leave it alone on the settings??
Old 07-22-2011, 10:51 PM   #10
SecretS13
SecretS13's Avatar
yea i have my chamber maxed out -
Old 07-22-2011, 10:53 PM   #11
SecretS13
SecretS13's Avatar
#/f/s-chassis/204855...-zilvians.html
i did this and put a bolt like this so it wont losen back up and rub when i drive
Old 07-23-2011, 12:16 AM   #12
ra21lover
okay i loosen up the knuckles didnt work i pulled the hub towards me no movement....i max my camber out help out a little bit....still hits...
Old 07-23-2011, 12:18 AM   #13
SecretS13
SecretS13's Avatar
only other bet i guess is extended studs with 10mm slip on
Old 07-23-2011, 12:34 AM   #14
h2v7
i thought megan had some sort of extender,that mounts to the coilover bracket, or whatever you had to buy?
Old 07-23-2011, 10:47 PM   #15
zerodameaon
zerodameaon's Avatar
get some 10 or 15mm bolt on spacers.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 07-24-2011, 12:26 PM   #16
ra21lover
okay i got the nismo extended studs today question should i get the 10mm or 15mm spacer??? will 10 mm do the job??? like i said before i just ried stacking the 5 and 3mm= 8 it helped a little it barely hits the collars....thanks for the input guys lmk thanks again....
Old 07-29-2011, 07:01 AM   #17
Mi BEAN
Mi BEAN is an unknown quantity at this point
any pics?? please want these rims and want to see them on
Mi BEAN is offline   Reply With Quote
Old 07-29-2011, 07:04 AM   #18
enkei2k
sell the wheels and get better fitting ones.
Ask enkei2k
xquizitditz
Old 07-29-2011, 07:25 AM   #19
alexanderig
On my s13 I had to run 15mm spacers with those wheels.
Old 07-29-2011, 09:40 PM   #20
ra21lover
thanks for the help its all down 15mm fronts and 5 mil rears perfect.
