I am trying to get a Z32 front cover, Z32 throw out arm, Z32 throw out bearing, Z32 pivot ball, and front cover gasket for a rb25 pull to push trans conversion. on this site i looked up the part number for the front cover and its 32110-40P00 and 32110-30P00. it looks like i need the 40p00 because it looks like the 30p00 was phased out. anyone know?
1990 z32--- 1990 Nissan 300ZX Transmission Case & Clutch Release - Diagram 2 3211612 1993 z32--- 1993 Nissan 300ZX Transmission Case & Clutch Release - 3211610 |
The only difference in early year Z32 transmissions is that the bell housings are slightly different. The twin turbo trannys have a thinner bell house to accommodate the larger flywheel of the twin turbo engines.
